Passer au contenu
Connexion
Rechercher
Rechercher Connexion Panier 0
Panier
Votre panier est vide.
  • Continuer les achats
    Sous-total
    Voir le panier
    Rechercher
    Link Nissan S15Link - #NS15X PlugIn ECU - AimShop.com
    NS15X
    En stock, prêt à être expédié
    £1,475.00
    • Partager sur Facebook
    • Partager sur WhatsApp
    • Partager par Email
    • Email Partager par Email
    £1,475.00
    Designed for the SR20 engine. This ECU will work with the 64 pins, blue header plug ECU version.
    ECU includes an onboard 4 bar MAP or 7 bar MAP sensor.
    Suitable Applications:
    S13 Silvia / 180SX SR20DET (but not CA18DET)
    S14a Silvia (facelift) SR20DET
    S15 Silvia SR20DET
    S15 Silvia SR20DE
    RNN14 Pulsar GTI-R SR20DET
    N15 Pulsar SR16VE
    N14 Distributed
    *For the 76 pin header ECU, have a look at the S13X PlugIn listing.
    Sequential fuel delivery
    OEM idle hardware supported
    CAN port
    USB tuning cable included
    Staged injection
    Knock with "windowing"
    I/O Expansion Options:
    Expansion connector 1
    Gnd Sensor Ground Only
    DI6 Digital Input
    DI7 Digital Input
    An Volt 5 Analog 0-5V input
    An Volt 6 Analog 0-5V input
    Expansion connector 2
    Ign 5 Ignition 5 Auxiliary output
    Ign 6 Ignition 6 Auxiliary output
    Ign 7 Ignition 7 Auxiliary output
    DI 8 Digital Input
    Volt 8 Analog 0-5V input
    Volt 9 Analog 0-5V input
    Volt 10 Analog 0-5V input
    Volt 11 Analog 0-5V input
    • G4X PlugIn ECU
    • Stickers
