Link Pressure Sensor 1/8" NPT (PS150)
Why Choose the Link Pressure Sensor
The Link pressure sensor is designed for precise monitoring of oil or fuel pressure, offering reliable readings up to 10 bar (150 PSI). It features a durable 1/8” NPT thread for easy installation into standard fittings and comes complete with a plug and pin kit for straightforward wiring and setup.
1/8" Capteur de pression à liaison NPT
Prise PS150 & Broches
