Passer au contenu
Connexion
Rechercher
Rechercher Connexion Panier 0
Panier
Votre panier est vide.
  • Continuer les achats
    Sous-total
    Voir le panier
    Rechercher
    Link Toyota MR2Link V1 - TST185X PlugIn ECU - AimShop.com
    TST185X
    En stock, prêt à être expédié
    £1,145.00
    • Partager sur Facebook
    • Partager sur WhatsApp
    • Partager par Email
    • Email Partager par Email
    £1,145.00
    Designed for the 3SGTE engine in the models specified below.
    A Link Air Temp Sensor is highly recommended with this ECU
    Suitable Applications:
    Toyota MR2 (SW20) from 1989 to 1992
    Toyota Celica ST185 (except the GT-Four RC/Carlos Sainz Special Edition which is compatible with the Link TST205X Plugin)
    Sequential fuel delivery
    OEM idle hardware supported
    CAN port
    USB tuning cable included
    Staged injection
    Knock with "windowing"
    I/O Expansion Options:
    Expansion connector:
    Gnd Sensor Ground Only
    DI 5 Digital Input for switching functions.
    DI 6 Digital Input for switching functions.
    DI 4 Digital Input for switching functions.
    An Volt 4 Analog 0-5V input
    An Volt 5 Analog 0-5V input
    An Volt 6 Analog 0-5V input
    An ignition expansion is provided allowing you to convert to a Direct Spark ignition system. Alternatively, these outputs can be used to drive auxiliary devices. The following pinout describes the available connections.
    Ignition Expansion:
    1 Ignition 1
    2 Ignition 2
    3 Ignition 4
    4 Ignition 3
    • G4X PlugIn ECU
    • Stickers
