Mount Your System
The Aim SmartyCam U Bolt Mount is a simple, but secure way of integrating your SmartyCam into a vehicle’s roll bar, railing or tube that has a diameter between 0.5 and 1.2 inches. It is compatible with the SmartyCam 2.1, 2.2, 3 and 4 Sport, Corsa & HD models.
Why Choose the Aim SmartyCam U Bolt Mount
The Aim SmartyCam U Bolt Mount is a versatile way to secure a SmartyCam to a range of vehicle setups. The mount is easy to set up; simply attach the U bolt to the vehicle, and secure using the lock nuts for a secure fit. The ball and socket system allows you to easily adjust your camera angle, while the rubber insert minimises vibration, ensuring you get the best recordings of your laps.
  • For use with SmartyCam HD, Sport & Corsa 2.1, 3 & 4 cameras
  • Ball & socket adjustment system
  • Suitable for 0.5 to 1.2" bar
  • Designed to withstand the rigours of motorsport
  • 1 U bolt & straps
  • 160mm single ball arm
  • 1 ball head
  • 1 washer diameter 17.7mm, thickness 1.5mm, hole 6mm
SKU: SM-UB
Part Number: X90KSTP00
