Aim Faisceau d'injection secondaire Taipan
Choose Accessories
Connect Your System
The Aim Taipan Second Injection Harness is an optional cable that pairs with the Taipan ECU to add another injection to a motocross bike. It is connected to the third connector on the Taipan ECU, has two other flying wires and measures 2.5m in total.
Why Choose the Aim Taipan Second Injection Harness
Typically, a motocross bike is limited to a single fuel injector. With the Taipan Second Injection Harness, you can add a second injector to allow for more advanced engine performance tuning.
Thanks to its convenient size and durable design, it will conveniently reach around your bike while remaining sleek and compact, making it ideal for any motocross setup.
Harness Options
Harnais de deuxième injection Taipan
Videos
