Aim Solo 2 & Plaque de support Solo 2 DL
Mount Your System
The Aim Solo Backing Plate is used for securely mounting Solo 2 and Solo 2 DL GPS Lap Timers onto most flat surfaces. It is ideal for use as a spare for people who need an extra mount for another vehicle, ensuring the quick and easy transfer of the Solo 2.
Why Choose the Aim Solo 2 Backing Plate
The Solo 2 has two large integrated magnets on the back that hold it in place. By attaching the spare backing plate to a flat, but visible surface, you can simply install or remove the lap timer with ease, ready for track days. For a more permanent and secure fitting, there are also options to screw the mounting bracket to the lap timer.
How do I mount the Aim Solo 2 in my vehicle, and does it come with mounting accessories?
The Aim Solo 2 comes with a universal mounting bracket, with optional accessories such as a suction cup, u bolt, or roll cage bracket. All mounting options provide a stable and vibration-resistant mounting solution, ensuring accurate data collection during your sessions.
Can the Solo 2 be mounted on a motorcycle?
Yes, the Solo 2/2 DL can be securely mounted using compatible motorcycle mounting brackets. Choose from a range of popular motorcycle makes including Aprilia, BMW, Ducati, Honda, Kawasaki, Suzuki and Yamaha.
