The Suzuki OEM Dash Upgrade: MXPS
The Aim MXPS is a state-of-the-art plug & play dash logger designed specifically for Suzuki GSX-R1000 and GSX-R1000R models from 2017 to 2022. This MXPS’ advanced system seamlessly integrates with your Suzuki dash, providing comprehensive data logging and a customisable display to enhance your riding experience.
The MXPS Suzuki GSXR-1000 Data Logger integrated into a bike dashboard
Why Choose the MXPS Suzuki Dash
The Aim MXPS offers a comprehensive upgrade to your Suzuki dash, combining modern aesthetics with advanced data logging capabilities. Whether you're on the track or on the road, the MXPS provides the information you need to enhance your riding experience.
Please Note: The MXPS dash can be programmed with your current mileage. Please state your required mileage in miles or kilometres in the notes section on your order.
Connections & Expansions
The MXPS plug & play dash logger is compatible with various expansions and modules to enhance performance and expand on data collection to get the best out of your GSX-R 1000. Compatible connections & expansions include:
  • Lambda Controller: Monitor your air-fuel ratio for optimal engine performance with the EXP connection.
  • USB or Wi-Fi Connection: Enables you to download data and configure your MXPS.
  • SDS+Analogue Connection: Gives you the possibility to read 28 ECU extra channels and 4 user-defined analogue inputs.
  • SmartyCam Cameras: Integrate video with data overlay for comprehensive analysis. Analogue camera input also allows you to swap your display into a mirror camera through push button command or event management.
Charger la vidéo: Delta times LED display feedback on the MXPS Suzuki Bike Display
User-Friendly Experience
The MXPS benefits from a user-friendly menu, ensuring that navigation and configuration of the dashboard is simple and clear. Setting up your MXPS is just a matter of riding style: choose what perfectly fits your road/track needs. The complete menu allows you to easily modify every parameter of your motorcycle: ECU maps, traction control, anti-wheeling, ABS and so on.
Charger la vidéo: Integrated shift light array interface and customisable alarms for the MXPS Suzuki Bike Display
The MXPS dash has 2 types of displays: road or track, in either analogue or digital themes, with light and dark modes for each to suit your preferences. There is also a wide range of icons available on the display, allowing you to easily see important information whilst you’re driving: fault indicator, oil pressure issues, water temperature, servicing indicator, fuel level etc.
The MXPS dash features 10 shift light LEDs, as well as 9 alarm LEDs showing high beam on, engine problems, traction control active/error, ABS active/error and configurable LEDs to name some of the alarm features.
The MXPS Suzuki Dash integrated into a Bike cockpit
Data Analysis
Equipped with a GPS09 Module, the MXPS provides precise GPS speed, lap timing and track mapping, automatically detecting circuits from its comprehensive database. With the MXPS racing kit, you can read 28 ECU extra channels and connect up to 4 sensors to gain insights into RPM, throttle position, temperature and more.
Once data is collected, it can be reviewed on the dash or analysed in-depth using Race Studio 3, which visualises performance insights through graphs, histograms and tables. Whether you're fine-tuning your setup for the track or aiming for personal bests, the MXPS dash logger provides everything you need to optimise your Suzuki’s performance and take your riding to the next level.
Advanced Data Acquisition
The MXPS transforms your Suzuki dash into a powerful data-logging system, capturing real time performance metrics from your motorcycle’s ECU, GPS Module and additional sensors and modules that have been added.
MXPS Expansions list; SmartyCam Series, ACC3, Data Hub, GPS and more.
The MXPS Suzuki dash is compatible with various expansions and modules to enhance performance and expand on data collection. Some of the compatible expansions include:
  • Display: 6" TFT
  • Resolution: 800x480 pixels
  • Contrast: 600:1
  • Ambient Light Sensor: Yes
  • Alarm LEDs: 9
  • Shift Light LEDs: 10
  • CAN Connections: 2
  • ECU Connection: Yes
  • External Modules: GPS Module, Channel Expansion, Lambda Controller, TC Hub, SmartyCam
  • Wi-Fi Connection: Yes
  • Internal Memory: 4GB
  • Body: Anodised Aluminium
  • Connectors: 1 32-pin JAE main connector + 4 binder 712 female connectors
  • Power Consumption: 400 mA
  • Weight: 620g
SN: 0500404
MXPS User Guide
MXPS Tech Sheet
MXPS Channels List
Videos
Installation
Charger la vidéo: Official installation of the plug & play MXPS dash on a Suzuki GSX-R 1000 (2017-2022) motorcycle
How do you upgrade the Suzuki GSX-R1000 Dash?
To upgrade your Suzuki GSX-R Dash, you can install the MXPS Dash Logger, which replaces the OEM unit on the GSX-R1000 and GSX-R1000R models. Installation is quick and easy thanks to the plug & play connectivity - simply fit the device into the OEM bracket and connect to the motorcycle's existing connectors. For a more in-depth tutorial, take a look at our MXPS Suzuki GSX-R installation in the "Videos" tab.
What are the key features of the Aim MXPS Suzuki GSX-R1000 Dash Logger?
The Aim MXPS Suzuki GSX-R1000 Plug & Play Dash Logger is a high-performance piece of motorsport equipment that offers an advanced and upgraded data logging experience, whilst having a range of additional features that make it easier to expand your system.
The MXPS Dash Logger has delta times shown, letting you compare your current lap with others to see exactly where you are gaining or losing seconds. It has customisable LEDs as well as a high contrast TFT display for optimised personalisation and ease in seeing your data in any condition.
The GPS module is also very accurate to 25Hz, allowing for advanced tracking capabilities and data collection. Ultimately, data collection is upgraded massively with the MXPS Dash Logger, with multiple motorcycle parameters being monitored and recorded for performance analysis.
Does the Aim MXPS Dash Logger work with other Aim products?
The Aim MXPS Dash Logger is designed to work with various other Aim products, acting as a central hub for data acquisition on the Suzuki GSX-R. It features an expansion port (via CAN connection) that allows for easy integration of additional sensors and systems to enhance performance monitoring. Please see the "Connections" tab for examples.
