This MXT is fully equipped and ready to take on its second life. The product is in full working order at a reduced price, and has been meticulously checked by our technicians.
Advanced PDM Display
The 10" PDM display with road icons is one of the most widely used PDM displays on roads around the world. It’s suitable for use as a replacement unit for those supplied with the Aim PDM kits or an upgrade for PDM kits that do not include a dash display.
Why Choose the 10” PDM Display
The 10" PDM display is a TFT dash display suitable for replacing all of the dashboard gauges and warning lamps. The displays are available in 5”, 6" or 10" versions and with both "Road" or "Race" icon options. All versions have fully user-configurable displays and offer a range of layouts.
Please Note: The 10" dash display is ONLY for use with Aim PDM kits and can not be used as a stand-alone dash display.
Display with Road Icons
The dash has a 10" TFT high contrast colour display. The visual quality is optimised by the ambient light sensor, which keeps the backlight at the best brightness levels.
Second Life <tc>Aim</tc> MXT 10" Écran de tableau de bord TFT PDM avec icônes routières
Add extra devices to your system to give additional data to improve your driving performance, such as a GPS Module, TC Hub, SmartyCams, LCU-One S Lambda Controller, Formula Steering Wheels, TPMS System and keypads.
The 10" road display also doubles up as a reversing mirror using a separately available camera—ideal for cars with limited rear vision. You can add up to 2 cameras for both front and rear views. The camera is sold separately.
Note: You will require a PDM32 for this to work.
  • Ambient Light Sensor: Yes
  • CAN Connections: 3
  • Digital Inputs: 4-speed input, lap signal, coil RPM input
  • Digital Outputs: 2 (1 Amp max)
  • Second CAN: Yes
  • Body: Anodised aluminium
  • Connectors: 2 Autosport connectors & 1 binder connector
  • Power Consumption: 450mA
  • Display: 10" TFT
  • Resolution: 1,280 x 480 pixels
  • Contrast: 1,100:1
  • Brightness: 800cd/m² - 1,200 Lumen
  • Weight: 1,200g
SKU: 8000380
MXT Strada User Guide
MXT Strada Tech Sheet
