Enregistreur de données de course EVO4S hors production de seconde vie
The EVO4S Data Logger
The EVO4S is a powerful and flexible data logger that offers a range of sources for your data. It is a great tool for track days to help improve your performance.
Why Choose the Aim EVO4S Data Logger
The Aim EVO4S power cable offers a direct, dependable power connection tailored for the EVO4S system, replacing worn or damaged cables without needing to rewire the entire harness. The power cable is rated for inputs from 9-15V and includes a battery ground lead, making it suitable for typical road or race electrical systems.
Essentially, the Aim EVO4S power cable is ideal when you need a reliable, OEM-style replacement or spare power cable to ensure consistent logger operation.
Powerful and Flexible Data Logging
The Aim EVO4S is a powerful and flexible data logger and comes equipped with an optional GPS Module. Offering one connector per channel the EVO4S samples all the information you need, data coming from your vehicle's ECU via CAN, RS232 or K-Line, from the internal accelerometers and gyro and the GPS Module.
Select which harness you require CAN, RS232 or OBD11, and select which GPS Module best meets your requirements. You can also upgrade your kit with our GS-Dash display and Formula Steering Wheel, allowing you to really improve your performance on track days.
Optional Expansions
- Channel Expansion: Permits to add 4 0-5 volt analogue channels for pressure, temperature sensors and potentiometers (suspension, steering angle). Two of these channels can be configured to receive digital inputs like wheel speed.
- TC Hub: Adds up to four "K" type thermocouple temperature sensors.
- LCU-One Lambda Controller: Wideband Lambda controller LCU-one, with Bosch LSC 4.9 probe provides air/Fuel data, lambda value and exhaust gas temperature.
- SmartyCam Cameras: Onboard cameras that overlay onto all your videos all the data sampled by your logger.
EVO4S
