Second-Life OTK Kart Non-Contact Throttle Sensor Kit
OTK Throttle Sensor Kit
The Complete OTK Kart Non-Contact Throttle Sensor Kit is designed specifically for OTK chassis karts, providing precise, reliable throttle position data without the wear and tear of traditional contact sensors.
Why Choose the Complete OTK Kart Non-Contact Throttle Sensor Kit
The Non-Contact Throttle Sensor Kit is tailored for OTK karts, so installation is straightforward and the fit is reliable. By adding throttle position to your data set, you unlock deeper analysis and more targeted driver development, which are key advantages in competitive kart racing.
How the Non-Contact Throttle Sensor Works
The Complete OTK Kart Non-Contact Throttle Sensor Kit uses a non-contact sensor to measure the position of the throttle pedal. Instead of relying on a physical wiper or potentiometer, it detects throttle movement magnetically, which means there’s no direct mechanical contact inside the sensor. This makes it highly durable and resistant to the vibrations and harsh conditions typical in kart racing. The magnets mount to the pedals and the sensor to the kart, with no messy wires getting in the way, and it gives an exact indication of the pedal position, measuring its travel and shows all values in percentage in a 0 to 100 range.
OTK Sensor & Patch Lead
Support de capteur de position du papillon
