This MyChron 5 is fully equipped and ready to take on its second life. The product is in full working order at a reduced price, and has been meticulously checked by our technicians.
The Aim MyChron 5 is our best-selling GPS specifically crafted for karting. Combining 30 years of experience with advanced technology, the MyChron 5 offers precise lap timing and advanced data analysis for both amateur and professional racers.
Why Choose the MyChron 5 GPS Lap Timer 
The MyChron 5 GPS lap timer revolutionises how drivers and teams monitor and analyse performance on track.
Due to its highly accurate 25Hz GPS tracking, large screen displaying lap times and comprehensive data logging capabilities, the MyChron 5 provides detailed performance analysis from split times and predictive times, racing lines, cornering speeds and braking points.
Advanced Display
The MyChron 5 features a wide graphical display, ensuring excellent readability. Brightness and contrast are automatically adjusted to maintain ideal visibility in all lighting conditions, and this allows drivers to clearly monitor their best vs current sector times.
LED & Alarms System
5 RGB shift lights can be customised to display lap times or function as traditional shift indicators. The 2 RGB alarm LEDs provide real time engine monitoring of vehicle temperature, ensuring the kart operates within optimal parameters and preventing overheating or potential damage.
  • GPS: 25Hz
  • Ambient Light Sensor: Yes
  • Multifunctional LEDs: 5 RGB LEDs
  • Alarm LEDs: 2 configurable
  • RPM Sampling Frequency: 50Hz
  • Body: Glass fibre reinforced nylon
  • Battery: Rechargeable Lithium
  • Memory: 4GB
  • Dimensions: 137 x 88 x 30mm
  • Weight: 390g
  • IP67
  • MyChron 5
  • Cable icon
    Chargeur de batterie avec câble
  • RPM Cable
  • Aim Water (Coolant) Temperature Sensor for Kart - AimShop.com
    Capteur de température choisi
MyChron 5S User Guide
Fiche technique MyChron 5S
