Dyn X Racing Seat
Step into the driver’s seat of true immersion with the Dyn X racing seat; the heart of your sim racing cockpit. Designed for comfort, precision, and authenticity, this isn’t just a seat; it’s your gateway to the adrenaline and challenge of the world’s most demanding racetracks.
Sim Racing Seat Features
Crafted in a GT-style design, the Dyn X racing seat delivers the perfect balance of support and ergonomics for long, intense sessions. To take versatility even further, the adaptable headrest system allows you to seamlessly transform the experience into a Formula-style seating position, putting you right in the cockpit of the fastest cars on the planet.
Whether you’re mastering endurance stints, fine-tuning your lap times, or chasing the thrill of open-wheel racing, the Dyn X racing seat ensures you stay locked in with comfort, stability, and uncompromising realism.
  • Ergonomics Group: 5 - 99th percentile (men)
  • Seat Shell Material: Fibreglass reinforced plastic (FRP)
  • Seat Fabric Material: Premium synthetic suede (eco-suede)
  • Seat Padding: Multi-density foam / shock-absorbent foam
  • Harness Slots: 5
  • Headrest: Detachable and adjustable
  • Outer Seat Depth: 500mm
  • Outer Seat Height: 925mm
  • Outer Shoulder Width: 575mm
  • Outer Bottom Width: 540mm
  • Mounting Width: 420mm
  • Inner Seat Width (Back): 360mm
  • Inner Seat Width (Front): 430mm
  • Shoulder Support Height: 625mm
  • Seat Depth: 465mm
  • Belt Slot Height: 55mm
  • Middle of Belt Slot: 700mm
  • Seat Back Depth: 130mm
  • Mounting Hole Distance: 290mm
  • Product Number: IXM-RS1-KB-NN-1 (Racing Seat)
SKU: CM-BS
Racing Seat User Guide
Fiche technique du siège de course
Videos
Dyn X Setup Overview
Charger la vidéo: Features & capable adjustments with the Dyn X racing simulator
