Passer au contenu
Connexion
Rechercher
Rechercher Connexion Panier 0
Panier
Votre panier est vide.
  • Continuer les achats
    Sous-total
    Voir le panier
    Rechercher
    Super B Andrena 12V15Ah-SC Lithium Battery - AimShop.com
    SB-15-SC
    En stock, prêt à être expédié
    Choose Accessories
    £650.00
    • Partager sur Facebook
    • Partager sur WhatsApp
    • Partager par Email
    • Email Partager par Email
    £650.00
    Light-weight, high-performance, safe and reliable lithium power battery, especially developed for motorsports. This battery equals a lead-acid battery of 40 to 60Ah, provided the alternator’s maximum current doesn’t exceed the battery’s maximum charge current of 52A. Designed in a standard rally casing. Suitable for 12V systems and for use in extreme environments.
    Lightweight Power
    With a weight of only 2.9kg /6.4lbs, the Andrena 12V15Ah-SC power battery saves up to 80% in weight in comparison to traditional lead-acid batteries and is only 1/3 of the size of a conventional battery. This improves not only the performance of your vehicle but also helps to increase the fuel economy.
    The power battery offers a high level of power, fast charging and a long, maintenance-free service life. It also has a stable and flat discharge which means you have over 80% of the batteries capacity available and you can leave your vehicle unattended for a much longer period compared to a lead-acid battery.
    Safe & Reliable
    Super B batteries are based on lithium iron phosphate technology (LiFePO4). This is the safest lithium  technology available today. On top of that our bespoke casing and electronics further increase safety  and durability. Due to its high ingress protection class (IP69) the battery is completely dust tight and  waterproof . Therefore the battery can be used in the most extreme environment as well.
    Performance
    Fast charging
    Lightweight
    Compact size
    Low self-discharge
    High discharge rates
    3 Year Warranty
    ELECTRICAL SPECIFICATIONS
    Nominal Capacity 10Ah
    Energy 192Wh
    Nominal Voltage 12.8V
    Open Circuit Voltage 13.2V
    Self Discharge <3% per month
    EqPb (Equals lead-acid)  40 to 60Ah
    MECHANICAL SPECIFICATIONS
    Dimensions (LxWxH) 249 x 96 x 141mm | 9.80” x 3.78” x 5.55”
    Weight 2.9 kg / 6.4lbs
    Case Material PC - ABS
    Ingress Protection IP69
    Charge Method CCCV
    Charge Voltage 14.3V - 14.6V
    Max Charge Current 52A
    End of Discharge Voltage 8V
    Discharge Current Continuous 240A
    Discharge Pulse Current (1 sec) 708A (47C)
    TEMPERATURE SPECIFICATIONS
    COMPLIANCE SPECIFICATIONS
    EAN-13 8718531360068
    Battery Designation 4IFpR27/66-6
    Data Sheet
    Technical sheet
    Guide
    Quick Start Guide
    User Manual
    User Manual
