Passer au contenu
Connexion
Rechercher
Rechercher Connexion Panier 0
Panier
Votre panier est vide.
  • Continuer les achats
    Sous-total
    Voir le panier
    Rechercher
    Super B Mason 12V20Ah BMS Lithium Battery - AimShop.com
    Fast Charging
    Compact & Lightweight
    Safest Lithium Iron Phosphate Technology
    Long & Maintenance-Free Lifespan
    Low Self-Discharge
    High Discharge Rates
    SB-20-M
    En stock, prêt à être expédié
    Choose Accessories
    £925.00
    Fast Charging
    Low Self-Discharge
    • Partager sur Facebook
    • Partager sur WhatsApp
    • Partager par Email
    • Email Partager par Email
    £925.00
    Super B Mason 12V20Ah Lithium Battery
    The Mason 12V20Ah power battery is light-weighted, compact and offers high performances. Thanks to its lithium iron phosphate technology and integrated BMS system this new generation battery is extremely reliable and offers optimal safety. This battery is developed for motorsport, motorcycle, automotive and marine applications. Suitable for 12V systems and for use in extreme environments.
    Lightweight Power
    With a weight of ±4.6kg /10.14lbs, the Mason 12V20Ah power battery saves up to 60% in weight in comparison to traditional lead-acid batteries and is only 1/3 of the size of a conventional battery. This improves not only the performance of your vehicle but also helps to increase the fuel economy.
    The battery offers a high level of power, fast charging and a long, maintenance free service life. It also has a stable and flat discharge which means you have over 80% of the batteries capacity available.
    Integrated BMS
    The Mason 12V20Ah power battery incorporates a Battery Management System (BMS) to ensure a high level of safety during use. The BMS constantly monitors the status of individual battery elements such as cell temperature, cell voltage, charge and discharge currents. The integrated BMS also provides cell balancing.
    Safe & Reliable
    Due to its high ingress protection class (IP66) the battery is dust tight and waterproof. Therefore the battery can be used in the most extreme environments as well.
    Performance
    Fast charging
    Lightweight
    Compact size
    Low self-discharge
    Integrated BMS
    3 Year Warranty
    ELECTRICAL SPECIFICATIONS
    Nominal Capacity 20Ah
    Energy 256Wh
    Nominal Voltage 12.8V
    Open Circuit Voltage 13.2V
    Self Discharge <3% per month
    EqPb (Equals lead-acid)  70 to 100Ah
    MECHANICAL SPECIFICATIONS
    Dimensions (LxWxH) 255 x 101 x 171mm | 10.0” x 4.0” x 6.7”
    Weight 4.6 kg / 10.14lbs
    Case Material PC - ABS
    Ingress Protection IP66
    Charge Method CCCV
    Charge Voltage 14.3V - 14.6V
    Max Charge Current 66A
    End of Discharge Voltage 8V
    Discharge Current Continuous 260A
    Discharge Pulse Current (1 sec) 892A (45C)
    TEMPERATURE SPECIFICATIONS
    COMPLIANCE SPECIFICATIONS
    EAN-13 8718531361812
    Battery Designation 4IFpR27/66-8
    Data Sheet
    Technical sheet
    Guide
    Quick Start Guide
    User Manual
    User Manual
