Triumph Daytona, Street Triple & Triple vitesse Aim Solo 2 DL Plug & Câble de jeu
Triumph Motorcycle ECU Connection
The Triumph ECU Plug & Play Cable allows you to connect Aim Data Loggers, such as the Solo 2 DL, ECULog, XLog or EVO4S, to the Triumph-specific connector. The Triumph ECU Cable provides an easy plug & play connection to the motorcycle's ECU on one end, and uses a metal 712 screw-on binder connector with 7-pins on the other end, allowing ECU data to be logged.
Plug & Play Cable
The plug & play cable has been specifically designed for the following Triumph motorcycle models and years:
- Triumph Daytona 675 – 2006-2012
- Triumph Street Triple – 2007-2012
- Triumph Speed Triple – 2007-2012
Example Data Protocols
Example data protocols sampled can include RPM, vehicle speed, manifold air pressure, throttle position, fuel level and many more. Refer to the user guide in the Downloads tab for a full protocol list.
Triumph Solo 2 DL Plug & Play Cable
