Mount Your System
The Yamaha Motorcycle Bracket has been specifically designed to provide a simple and secure mounting solution for Aim Solo 2 and Solo 2 DL Lap Timers. The bracket is compatible with Yamaha YZF-R1/R1M (YEC incl.) motorcycles from 2015-2019 and YZF-R6 motorcycles from 2017-2020.
Why Choose the Aim Solo 2/2 DL Motorcycle Bracket
The Aim Solo 2/2 DL Motorcycle Bracket ensures your Solo 2 GPS Lap Timer can be securely mounted on your Yamaha motorcycle. Supplied with all the necessary hardware, it provides a quick and stress-free installation, so you can accurately track and monitor your laps with ease.
Yamaha YZF R1M Motorcycle
Plug & Play Cable
A separately sold plug & play cable is also available for the following Yamaha motorcycle models and years:
  • Yamaha YZF-R1 (YEC Included) – 2015-2019
  • Yamaha YZF-R1M (YEC Included) – 2015-2019
  • Yamaha YZF-R6 – 2017-2020
If you are unsure whether this bracket will fit your motorcycle, don't hesitate to contact our team.
  • For Yamaha motorcycles only
  • Compatible with YZF-R1/R1M (YEC incl.) 2015-2019 and YZF-R6 2017-2020
  • Mounting bracket for the Solo 2 & Solo 2 DL Lap Timers
SKU: YAM-1-B
Part Number: X46KSYR115
  • Support Yamaha YZF-R1/R1M/R6 Solo 2/DL
  • x2 Vis Allen à Tête Plate M4x10mm
  • x1 vis Allen à tête plate M6
  • x1 cheville en caoutchouc
  • Washer icon
    x1 rondelle en caoutchouc
Guide de l'utilisateur Yamaha YZF-R1/R1M/R6
