Yamaha YZF-R1 & YZF-R6 Aim Solo 2 & Support de moto Solo 2 DL
Choose Accessories
Mount Your System
The Yamaha Motorcycle Bracket has been specifically designed to provide a simple and secure mounting solution for Aim Solo 2 and Solo 2 DL Lap Timers. The bracket is compatible with Yamaha YZF-R1 (YEC incl.) motorcycles from 2004-2014 and YZF-R6 (YEC incl.) motorcycles from 2004-2016.
Why Choose the Aim Solo 2/2 DL Motorcycle Bracket
The Aim Solo 2/2 DL Motorcycle Bracket ensures your Solo 2 GPS Lap Timer can be securely mounted on your Yamaha motorcycle. Supplied with all the necessary hardware, it provides a quick and stress-free installation, so you can accurately track and monitor your laps with ease.
Plug & Play Cable
Separately sold plug & play cables are also available for the following Yamaha motorcycle models and years:
- Yamaha YZF-R1 (YEC Incl.) – 2004-2008 & YZF-R6 (YEC Incl.) – 2006-2016
- Yamaha YZF-R1 (YEC Included) – 2009-2014
- Yamaha YZF-R6 (YEC Included) – 2004-2005
If you are unsure whether this bracket will fit your motorcycle, don't hesitate to contact our team.
Support Yamaha Solo 2/2 DL
x2 Entretoises
x2 Écrous Autobloquants M6
x4 Rondelles M6
x2 Écrous Autobloquants M4
x2 Rondelles M4
x2 Vis Allen à Tête Plate M4x10mm
x2 Vis Allen à tête ronde M6x60mm
