Aim רתמת דויטש בעלת 22 פינים לסדרת MX
Deutsch Harness for MX Display Loggers
The Aim 22-Pin Deutsch Harness for MX Display Loggers gives you expanded input/output capability for your Aim MX Logger, enabling a more advanced wiring setup without swapping the main wiring loom. The 22-Pin Deutsch Harness includes a 22-pin Deutsch female flying connector and a 4-pin 719 female Binder. It connects into the 22-pin socket on your MX Data Logger, giving you access to analogue sensor channels 5-8, digital wheel speed sensor inputs 2-4, and digital 12V outputs 1-2, plus an RS232 ECU connection.
Why Choose the Aim 22-Pin Deutsch Harness
The Aim 22-Pin Deutsch Harness is built to integrate with Aim MX Display Loggers, offering additional channels and advanced functions in a compact, motorsport-ready harness.
The standard 37-Pin Harness that comes with the logger supports only 4 analogue channels; this harness expands your capability for things like steering angle, throttle position, gearbox input and differential temperature. It is suitable for installation in race or track vehicles using the MX Logger Series.
רתמת דויטש MX Logger עם 22 פינים
