Aim EVO6L Racing Data Logger
Choose Accessories
Free Shipping Above £100
Professional Data Logger
Unlock professional-level data logging in a compact, efficient package with the Aim EVO6L Racing Data Logger, engineered for racers who need powerful performance without the bulk. Delivering precise data acquisition in tight installations, the EVO6L combines advanced GPS tracking, inertial measurement, and flexible sensor inputs into a streamlined unit. Small in size, big on insight; this is the smart way to capture performance.
Why Choose the EVO6L Racing Data Logger
The EVO6L Racing Data Logger is built for racers who want a clean, efficient data system without sacrificing capability. Its compact footprint makes it perfect for tighter cockpits, bikes, or lightweight race cars, while still delivering synchronised GPS, IMU, and vehicle data for complete performance analysis. With seamless integration into Aim’s ecosystem, you can expand your system as needed while keeping your core setup simple and effective.
If you’re looking for a lightweight, high-performance data logger that delivers exactly what you need, no more, no less, the Aim EVO6L Data Logger is your solution.
EVO6L Features
The EVO6L features 5 fully configurable analogue inputs that support a wide range of sensors, including temperature and pressure, along with 2 speed inputs and coil RPM acquisition for accurate monitoring of vehicle speed and engine behaviour. An integrated 25Hz GPS09 module provides precise lap timing and track positioning, while a 100Hz 3-axis IMU (±5G) captures acceleration, braking, and cornering forces in real time for detailed analysis of driving dynamics.
Built-in Wi-Fi and Bluetooth enable fast, cable-free configuration and data downloads, and 4GB of internal memory ensures reliable storage across multiple sessions so critical data is always captured. Its ultra-compact design, combined with Binder connector integration, makes it ideal for installations where space is limited while still maintaining robust connectivity and durability.
A Range of Data Sources
The EVO6L provides comprehensive data acquisition from multiple sources, including your vehicle ECU via CAN, RS232 or K-line, along with the internal accelerometers and gyro, and the GPS09 receiver included in all available kits. It also supports analogue and digital inputs, external expansions, and predefined math channels for added flexibility.
Sensors can be connected to 5 configurable analogue channels, the RPM input, and up to 2 wheel speed inputs, delivering a compact yet powerful solution for vehicle data logging.
Connection Type
The EVO6L uses 13 various 712 female Binder connectors to provide simple, reliable, and flexible connectivity for all system functions. This connector layout supports power, CAN communication, sensor inputs, digital outputs, and additional expansion features, making installation and integration straightforward across a wide range of vehicle applications.
Digital & CAN Outputs
The EVO6L Data Logger features one low-side digital output (switch to ground), configurable to automatically activate or deactivate external systems according to the value of analogue or digital inputs. This can be used to control devices such as auxiliary lights, cooling fans, circulation pumps, and other systems when predefined events occur.
The EVO6L also includes CAN Output functionality, enabling messages to be transmitted directly to an existing CAN network for enhanced vehicle control and integration.
Sensor Compatibility
Sensors can be connected to the EVO6L Data Logger via:
- 5 analogue channels with configurable inputs or thermocouple input, with a max frequency of 1,000Hz each, used to sample data coming from temperature, pressure, suspension and other kinds of sensors.
- 2 speed inputs that allow you to monitor the different wheels' behaviours.
- 1 RPM input, which manages square wave signals transmitted by the ECU, or pulse signals picked from the coil command (low voltage).
EVO6L
Chosen GPS Module
Your Chosen Connection Cable
EVO Power Cable
712 to USB Cable
| Specs |
EVO6L Data Logger
EVO6 Data Logger
ECULog Data Logger
XLog Data Logger
