Aim כבל חשמל חיצוני 7 פינים של SmartyCam
Power Your System
The Aim SmartyCam 7-Pin External Power Cable provides a direct power supply to the Aim SmartyCam 3 & 4 Corsa, 3 GP and 2.2 GP/GP HD cameras. It provides external power from a 12V battery system using the two unterminated wires and features a 712 7-pin binder for a secure connection to the camera.
Why Choose the SmartyCam External Power Cable
The Aim SmartyCam 7-Pin External Power Cable is ideal if you want the reassurance of having your SmartyCam powered from an external 12V battery system. It features two flying cables and comes in a 2m cable length to suit a variety of motorsport setups.
SmartyCam 7-Pin Power Cable
