Aim כבל חיבור למצלמת SmartyCam Bullet
Connect Your System
The Aim SmartyCam Bullet Camera Connection Cable has been designed to be fitted between the recorder box and the bullet camera. There are a range of different lengths available, ranging from 1 to 4 meters, and you can choose a custom-sized cable to fit inside your specific set up.
Note: Returns are not accepted for custom cable lengths.
Why Choose the Aim SmartyCam Connection Cable
The Aim SmartyCam Bullet Camera Connection Cable allows you to connect your bullet camera to the recording box on any SmartyCam 2.2 & 3 GP & GP Pro to get the most out of your camera setup. The connection cable is available in many different sizes, allowing you to select one that works for you. There are custom sizes available too, ensuring that anyone can expand their Aim setup.
As the bullet camera cable has been specifically designed for motorsport environments, it is a high quality & long-lasting product that will withstand the rigours of motorsport so you can record your laps with ease.
כבל חיבור למצלמה של Bullet
