Aim Solo, Solo 2 & Solo 2 DL Suction Cup Mount
Mount Your System
The Aim Suction Cup Mount secures any Aim Solo GPS Lap Timer to the windscreen or any flat surface, so that you can easily and accurately measure your lap times. Using the suction cup mount, you can position the screen to face anywhere you want, and the 90mm lock and quick-release suction cup features allow for secure attachment and quick detachment.
Why Choose the Aim Solo Suction Cup Mount
Designed specifically for the Aim Solo, Solo 2 and Solo 2 DL, the suction cup provides a strong and secure mounting solution, ensuring the lap timer won’t move, fall or cause any distractions to the driver. The dual swivel joint makes it easier to conveniently position the lap timer to face you, so that you can quickly monitor and improve your timings hands-free, without compromising on visibility.
תושבת כוס יניקה סולו
