AiM Solo 2 & Solo 2 DL Backing Plate
SKU: SOLO2-BP-C
- מחיר רגיל
- £21.00
- מחיר רגיל
- מחיר מבצע
- £21.00
- מחיר ליחידה
- לְכָל
+ מע"מ (בריטניה בלבד)
The AiM spare backing plate designed for mounting the Solo 2 & Solo 2 DL GPS Lap Timer.
Spare backing plate | Suitable for Solo 2 & Solo 2 DL GPS lap timer |
Solo 2 / Solo 2 DL Spare Backing Plate
The AiM spare backing plate to suit the Solo 2 & Solo 2 DL enables you to mount your Solo 2 GPS Lap Timer to most flat surfaces. The Solo 2 has two large integrated magnets on the back that hold it in place, so you can simply install or remove it with ease. Allowing you to fit into additional vehicles.
Solo 2 & Solo2 DL mount ideal for use as a spare
Mount onto flat surfaces
- 1 Solo 2 / Solo 2 DL Backing Plate
- 2 screws
- 2 washers
- 2 nuts
- Solo 2 / Solo 2 DL Backing Plate
The AiM spare backing plate designed for mounting the Solo 2 & Solo 2 DL GPS Lap Timer.Key Features :
The AiM spare backing plate to suit the Solo 2 & Solo 2 DL enables you to mount your Solo 2 GPS Lap Timer to most flat surfaces. The Solo 2 has two large integrated magnets on the back that hold it in place, so you can simply install or remove it with ease. Allowing you to fit into additional vehicles.Solo 2 & Solo2 DL mount ideal for use as a spare
- 2 screws
- 2 washers
- 2 nuts
