Two-Way CAN Connection Multiplier
The compact two-way data hub with an external power cable provides two additional CAN channels and works as an interface between Aim data loggers and accessories. It also features a 12V external power connection.
Why Choose the Two-Way Data Hub
Using many devices can result in excessive wiring, but with the data hub, all unnecessary wiring can be eliminated. Aim data hubs take all the information you need to your logger with only one cable, minimising wires overall, and are available in the following versions to suit your setup:
The compact two-way data hub with 12V flying cables provides a CAN channel and works as an interface between Aim loggers and accessories. Additional devices, such as GPS modules, TC hubs (thermocouple multipliers), SmartyCams and Lambda sensors can be added to provide extra data from your vehicle and improve performance.
You can also use the two-way data hub with external power cable with our MX series dashes and display loggers, powered by the vehicle's onboard battery supply.
Note: You can connect multiple data hubs to build a wider network.
Connection
  • 5-Pin 712 Male Binder
  • 2 Flying Leads 12V
  • Dimensions: 70 x 30 x 23.5mm
  • CAN Cable Length: 40cm
  • Source Cable Length: 165cm
  • Weight: 86g
SKU: S-2PH-K
Data Hub Tech Sheet
