Ducati 848, 1098, 1198 Aim Solo 2 & Solo 2 DL Motorcycle Bracket
Choose Accessories
Mount Your System
The Ducati Motorcycle Bracket has been specifically designed to be a simple and secure way of mounting your Aim Solo 2 or Solo 2 DL Lap Timers. The bracket is compatible with Ducati 848, 1098 and 1198 motorcycles.
Why Choose the Aim Solo 2/2 DL Motorcycle Bracket
Supplied with all the necessary hardware, the Aim Solo 2/2 DL Motorcycle Bracket ensures that your Solo 2 GPS Lap Timer can be securely mounted to your Ducati motorcycle. This allows you to easily monitor your performance after a track day or practice to chase your desired improvements.
Plug & Play Cable
A separately sold plug & play cable is also available for the following Ducati motorcycle models and years:
- 848 Base/EVO/EVO Corse – 2007-2013
- 1098 Base/S/S Tricolore/R – 2007-2009
- 1198 Base/S/S Corse/R Corse/SP – 2009-2011
If you are unsure whether this bracket will fit your motorcycle, don't hesitate to contact our team.
Ducati Bracket
x2 ברגי אלן עם ראש שטוח M4x10 מ"מ
x2 אגוזי נעילה עצמיים M4
