G5 Voodoo Neo 6
G5 Voodoo Neo 6
G5 Voodoo Neo 6
The next generation of engine management for many more engines.
The G5 Voodoo Neo 6 Can Run:
- 8 cylinder port or direct injection and direct spark, or
- 6 cylinders with direct/port staged injection, and direct spark
The G5 Voodoo processing units are the perfect choice for professional-level motorsport.
G5 Voodoo Neo Key Features
- An all-new communications module: 10x faster USB speeds (from minutes down to seconds to download log files), Ethernet, and enhanced Wi-Fi and GPS.
- 1GB onboard of logging memory, double that of other Link ECUs.
- Highly customisable IO, using 2 types of multi-purpose pins: Injection/Ignition/Aux pins and dual-purpose ADIO pins.
- Dual on-board E-throttle, with H-bridges that now natively support things like modern e-wastegates or e-blow off valves
- 1 onboard wideband
- Configurable Analogue Temp inputs, with two different pull-up resistor values (1kΩ and 10 kΩ), allowing more types of sensors to be used
- Analogue Temp pull-ups can be disabled now, allowing Analogue Temps to be used as regular Analogue Volt inputs.
- K-line support.
- CNC Case, Sealed enclosure
Huge Time & Flexibility Gains
- You can now power via the USB cable, just like the Razor PDM, making setting up the initial tune a breeze at your PC.
- More mounting options than ever before, with through holes, and threaded mount holes on the side and underneath.
- New WEIPU CAN connector supplies power for CAN devices, massively simplifying CAN wiring and accessory installation.
- Highly customisable IO, with multi-use pins to maximise utilisation.
- Similar pinouts to G4X, allowing upgrades with minimal repinning.
Neo 6
Videos
Introducing The G5 Voodoo Neo
