The UK’s Leading Live Streaming Device
Take your live streaming to the next level with LiveU Solo PRO – the professional-grade, portable video encoder trusted by motorsport creators, sports teams, videographers and broadcasters worldwide.
Whether you’re transmitting SmartyCam 3 GP, GP Pro, or Dual footage straight to the pit, or streaming live to YouTube, Facebook, Instagram, Twitch and beyond, the LiveU Solo PRO delivers broadcast-quality 4K video with the reliability and freedom you need.
Why Choose the LiveU Solo PRO
Get rock-solid performance even in challenging network conditions. Enjoy up to 20Mbps streaming and optional HEVC/H.265 encoding for maximum quality at minimum bandwidth. Available in HDMI or SDI versions, the LiveU Solo PRO ensures your live streams look as good as your vision.
Designed for Creators
Join thousands already using the Solo Creator Universe (SCU):
  • IRL Streamers – Go live anywhere, wire-free and stress-free. Add Solo Connect PRO, your creativity and a camera – then just go!
  • Production Houses – Stream live events from anywhere with IP-video over bonded 4G/5G, no cables or venue networks required.
  • Sports Teams – Bring fans closer with easy-to-use, budget-friendly, broadcast-quality live streams.
  • Educational Institutions – From sports coverage to media training, the LiveU Solo PRO offers primetime results in a cost-effective package.
  • Videographers – Trust award-winning tech with HEVC, 4K, LRT™, long battery life and lightweight mobility so you can focus on storytelling.
Future-Proof Your Streaming
With the next-gen Solo PRO encoder, you can stream to any leading social platform or website. Simply connect your camera or switcher, log in via the web-based Solo Portal, select your destination, and go live.
Solo Creator Universe Services & Accessories
  • LRT™ Bonding Technology – Adaptive bitrate, bonded connections, and unmatched stability. Available monthly or annually.
  • Solo PRO Connect Kits – Complete plug-and-play packages with modems, data plans, and LRT™ included (two or four modem options).
  • Stream Tools – Multi-destination streaming, stream fallback, and logo watermark for enhanced brand presence.
  • Solo Belt Pack – Comfortable, practical, and designed for streaming on-the-go. Includes Y-cables, HDMI pigtail cable and space for modems/routers.
Trusted Worldwide
The LiveU Solo PRO is used by global broadcasters and streaming partners including:
Facebook, YouTube, Twitch, Vimeo, Twitter/X, Amazon Live, Dacast, Streann, Switchboard, Ustream, Grabyo, LinkedIn, Restream, Jstream.
Stream without limits – wherever the action takes you.
  • Video Resolutions: 4Kp60/59.94/50/25/30/29.97/24, 1080p50/60/25/30/24, 1080i50/60, 720p50/60, PAL, NTSC
  • Video Interfaces: 12G/3G/HD/SD-SDI and HDMI 2.0
  • Video Encoder: H.265/HEVC, H.264
  • Audio Encoder Supported Bitrates: 96/128/256Kbps (AAC-LC)
  • Portability: Professional-grade cross-shoulder pack and belt pack options
  • Simultaneous Bonding: Up to 6 network links: 4 x external cellular modems (4G/5G), WiFi and Ethernet
  • Power Sources: 3 hours internal battery, USB-C power input, support for different types of USB-C power sources with a minimum of 45-watt power delivery
  • Local Control: Full monitoring and control using a local 2.2” display and a user-friendly rotating jog
  • Remote Control: Full web-based remote control from smartphones, laptops, tablets or any web browser
  • Display Information: Video preview; per network cellular connectivity status, incl. throughput, network delay etc
  • Resienscy & Quality: Enabled by LiveU Reliable Transport (LRT™), featuring proprietary algorithms
  • Interfaces: 2 x USB 2.0, RJ-45 Ethernet, USB-C (for power only)
  • Wireless Interfaces: WiFi 802.11 a,b,g,n,ac support with internal MIMO antennas
  • Temperature: Operating: -5°C to +45°C
  • CDNs: Facebook, YouTube, Twitch, Vimeo and RTMP/S and more
  • Dimentions: 112.5mm x 188mm x 54.5mm (W x H x D)
  • Weight: 912g HDMI configuration
SKU: LU-SOLO-PRO-HDMI
  • LiveU Solo PRO SDI  4/5G Live Video Streamer - AimShop.com
    LiveU Video/Audio Encoder
  • Angled USB 2.0 Type A Cable
    2x Angled USB 2.0 Type A Cable
  • Cable icon
    HDMI Female - HDMI Male Cable
  • HDMI Voltage Clip icon
    HDMI Voltage Clip
  • Cable icon
    UK, EU & US Power cables
