דלג לתוכן
התחברות
חיפוש
חיפוש התחברות עגלה 0
עגלה
ההזמנה שלך כרגע ריקה.
  • המשך בקניות
רכשו בעוד £50.00 כדי לקבל משלוח חינם!
    הערות מיוחדות להזמנה
    מיסים ומשלוח מחושבים בתשלום
    סכום ביניים
    צפייה בעגלה
    חיפוש
    Second-Life SmartyCam 3 Sport 67º 01/07 - AimShop.com
    מחיר מבצע£532.00
    מחיר רגיל £665.00
    View available product
    This site is protected by hCaptcha and the hCaptcha Privacy Policy and Terms of Service apply.
    • שתף בפייסבוק
    • שיתוף בוואטסאפ
    • שיתוף על ידי אימייל
    • שתף בפייסבוק שתף בפייסבוק
    • WhatsApp שיתוף בוואטסאפ
    • אימייל שיתוף על ידי אימייל
    This SmartyCam 3 Sport camera with 67º lens comes back to us as a trade-in, fully equipped and ready to take on its second life. The camera is in full working order and has been meticulously checked by our technicians.
    Capture. Replay. Overlay. Analyse.
    Full HD recording. Crystal Clear Video. TFT Colour display. Automatic Start/Stop. Real-time overlay videos. Configurable. Choice of lens and can cable. Wave & Wobble eliminated. Waterproof.
    Please Note: The SmartyCam 3 Sport must be powered and connected to another Aim device such as the Solo 2 DL, MXM, or an MX-Series Data Logger/Strada Logger, in order to receive all CAN information. Please also be aware that the camera MUST be externally powered by any of these products as the internal battery is only competent for initial configuration.
    The SmartyCam 3 Sport saves all your data to a supported micro-SD card for up to 2TB of data. This includes speed, RPM, lap number, gear shifts and many more features. With a built-in data logger running on an external power of 9-15 volts, the new SmartyCam 3 automatically powers on and off in-sync with your engine and will auto start/stop recording, the parameters of this being personalised by the user.
    Analyse your data from a vast range of sources such as ECU information, GPS information, track map, vehicle position, speed, lap & split times. Video format is at H.264 1920x1080 pixels, 30 FPS, and the display resolution of 128x128 pixels gives your footage crisp condition. Our quality doesn’t falter, even under the pressure of extreme motorsport conditions such as poor weather, strong vibrations, continuous rain, and high/low temperatures as extreme as -10°C to + 50°C. Our camera is also waterproof (IP65) for extra protection.
    smartycam icon
    With the built-in data logger, you can view all the channels displayed on the video footage and review them with our new Race Studio 3 analysis software. Such channels include RPM, throttle, engaged gears, acceleration, temperatures, and pressures including a tri-axis accelerometer.
    smartycam icon
    Quality
    The SmartyCam 3 Sport includes a global shutter CMOS sensor and a low distortion lens with a field of view of 67° covering all areas. Its lightweight 200g (battery included) framework is infallible in providing you with smooth and effortless footage.
    smartycam icon
    Anatomy
    The SmartyCam 3 Sport contains a rechargeable lithium battery confined inside its 79.9x54x6.5mm body and has a 1 x 712 5 pin female binder connector that the camera can be directly connected to with any of our supported dashes, lap timers and loggers that supply the camera with power and CAN information directly from your vehicle.
    Finished with a sleek new look, the SmartyCam 3 is assured to add efficiency, informational data, productivity, and style to your racing. Aim SmartyCam 3 Sport is lighter, sleeker and even better than ever. Here at Aim, we provide only the best innovations and are constantly and consistently working to better your racing experience.
    smartycam icon
    Higher Storage Capacity
    Generic HD cameras focus too much on pixel numbers resulting in large file sizes. The SmartyCam 3 footage has the same quality as other FHD cameras with smaller files due to H.264 compression system parameters being optimised to a perfect balance between video quality and file size. Choose between three file quality levels: One hour recording = 4GB (High Quality), 2GB (Normal Quality) or 1.5GB (Lower quality).
    SD cards sold separately.
    smartycam icon
    The SmartyCam 3 Sport can be connected through the CAN network to our Aim Loggers, MX Series, MXL2, MyChron, Solo 2 DL, EVO5 and ECU Bridge.
    smartycam icon
    With Race Studio 3, you can create, modify, delete, import and export configurations with all channels, ECU drivers, Math channels, Display Pages, Digital outputs, Alarms, Shift Lights and all the expansions you need. You will also be able to manage the map of all your racing tracks and compare two laps by watching the video recorded by SmartyCam cameras.
    With Race Studio 3, you can also analyse all data recorded by the SmartyCam and download it to your PC: graphs, histograms and tables will help you study your performance, providing objective support to avoid mistakes and improve performance.
    Technical Specifications
    • Video format: H.264 1920 x1080 pixels @ 30 fps
    • Display resolution: 128 x 128 pixels
    • CMOS sensor: Global Shutter
    • Field of view: 67°
    • External power: 9-15 Volt
    • Support microSD card: Up to 2 TB
    • Connectors: 1 Binder 712 female
    • Auto Power ON: Yes
    • Auto Power OFF: Yes
    • Dimensions: 79.9 x 54 x 46.5 mm
    • Weight: 200g, battery included
    • Waterproof: IP65
    smarty cam 3 sport connectors
    Whats in The Box
    • SmartyCam 3 Sport
    • Data Hub (Optional)
    • 12v Mains Charger
    • 2m / 4m CAN Cable
    User Guide Technical sheet
    Use our 24/7 AI chat support, or call us from Monday to Friday between 09:00 and 17:00 BST
    Next-day delivery options available, and same-day shipping guarantee when you order before 15:00 BST Monday - Friday
    • נפתח בחלון חדש.
