חיים שניים Aim מתג כידון Taipan עם כבל קצר סטנדרטי
חיים שניים
The Advanced Handlebar Switch
The Handlebar Switch (HBS) is a second generation compact, high-performance, ergonomic handlebar switch by Aim.
If you're looking for a highly flexible switch for your handlebars, HBS offers a complete solution with 4 push buttons and 11 integrated LEDs.
Why Choose the Handlebar Switch
You can activate traction control with the HBS to stop your wheels from spinning when you apply any excess power. The Handlebar Switch can also be used to activate launch control, which will assist you to accelerate from a standing start.
Up to 5 Selectable Maps
Taipan ECUs can manage up to 5 maps, and these maps can be selected by OEM switches, such as Honda, Husqvarna, and KTM. The Handlebar Switch makes this far easier!
Taipan ECUs and HBS are fully compatible with all the stock handlebar switches. Plus, HBS allows the management of quick shifting on factory-equipped bikes.
