Vai direttamente ai contenuti
Accedi
Cerca
Cerca Accedi Carrello 0
Carrello
Il tuo carrello è vuoto.
  • Continua lo shopping
    Ordina istruzioni speciali
    Subtotale
    Visualizza carrello
    Cerca
    Aim 22 Pin Deutsch Harness with 1 Thermocouple for MX Series - AimShop.com
    H22-ST-V02573080
    Aim 22-Pin Deutsch Harness with 1 Thermocouple for MX Series
    In magazzino, pronto per la spedizione
    £320.00
    • Condividi su Facebook
    • Condividi su WhatsApp
    • Condivide via e-mail
    • E-mail Condivide via e-mail
    £320.00
    Aim 22 Pin Deutsch Harness with 1 Thermocouple MXS, MXP, MXG
    The Aim 22 pin Deutsch Harness has been designed to allow you to connect a thermocouple sensor to your device.
    Suitable for MXS, MXP, MXG Optional harness
     One K type thermocouple 22 pin harness
    22 pin Optional Harness with Thermocouple Connector for the MX Series
    The Aim 90° 22 pin harness plugs into the 22-pin connector on the MXS, MXP or MXG dash loggers.
    This harness has been designed to enable you to connect a K type thermocouple sensor to your device.
    Several of the advanced functions rely on this harness, which is not included with the standard 37 pin harness which comes as standard with the dash loggers.
    The 22 pins optional harness provides access to the following functions:
    Digital 12V outputs 1, 2
    RS232 ECU connection
    Please Note: The standard harness that comes with the MXS, MXG, and MXP allows 4 inputs. If you would like more inputs for your race data then add this optional harness to your kit.
    We have a choice of thermocouple sensors that can be added to your kit. The Aim Exhaust Gas K Type Temperature Sensor M5, Water Oil Temperature M5, Water/Oil Temperature Sensor M10.
    • 22 pin Deutsch Female Flying Connector
    • Table of non-ended cables  - See table in Downloads Tab
    • Thermocouple Connector - See table in Downloads Tab
    • 22 pin Deutsch Harness with one Thermocouple connector
    Technical sheet Race Studio 3
