Analogue Connection Harness for MX Stradas
The Aim 23-Pin Analogue Connection Harness enables expanded input channels for your MX Strada Displays, making installation clean and flexible in motorsport-based vehicles. This harness features a 23-pin AMP female connector and pre-wired leads terminated with 719 female Binder plugs. It provides analogue channels 1-4, speed and lap inputs, RS232 tx/rx and a digital output/CAN2+/- line for use with your MX Strada Dash.
Why Choose the Aim 23-Pin Analogue Harness
The Aim 23-Pin Analogue Connection Harness is ideal for installation in motorsport vehicles, track cars or motorcycles where extra sensor inputs are required to monitor throttle position, brake pressure, suspension travel or differential temperature. It unlocks additional analogue, speed and lap sensor inputs for your MX Strada Dash. With pre-terminated connectors, it saves time, reduces wiring errors and ensures compatibility with your Aim dash system.
  • 23-pin AMP female connector
  • x4 1x0.5 cables
  • 4x0.35 cables +
  • 3x0.35 cables
  • 4-pin 719 female Binder
SKU: MX-S-L-AN
Part Number: V02573330
Aim 23-Pin Strada Analogue Loom pinout
Scheda tecnica del cablaggio MX Strada
