Connect Your System
The 712 Male 5-Pin to RCA/712 Binder Patch Lead is perfect if you are replacing a damaged lead or modernising your setup, providing perfect compatibility with MX Series Dash Displays. Their design allows clean, direct integration without complex wiring, so the video feed is delivered reliably into your dash display for real time rear-view visuals.
Why Choose the Aim Reversing Camera Patch Lead
The Aim 712 Male 5-Pin to RCA/712 Binder Patch Lead is designed for connecting a reversing or mirror camera to your MX Series Dash Display, giving you rear-view video capability directly on your dash, whether this is a single or dual camera option.
Camera Compatibility
Our Reversing Mirror Camera Patch Leads are available in several different options depending on your setup:
  • Single Binder Cable: Ideal for connecting a single Aim Reversing Mirror Camera - 6m cable with 712-712 male to female 5-pin Binder connectors.
  • x2 Binder Cable: Ideal for connecting 2 x Aim Reversing Mirror Cameras - 1.5m cable to the split, then 2.5m & 4.5m patch leads from the split, with 712-712 male to female 5-pin Binder connectors. The cable is 6m at its longest length.
  • Single RCA Cable: Ideal for connecting a single non-Aim camera with RCA connection - 5m cable with a 712 male 5-pin Binder connector to RCA cables.
  • x2 RCA Cables: Ideal for connecting 2 x non-Aim cameras with RCA connection - 1.5m cable to the split, then 2.5m & 4.5m patch leads from the split. The cable is 6m at its longest length.
  • Ideal for connecting reversing mirror cameras to an MX Display
  • 712 male 5-pin connector on one end
  • Choice of connectors on the other end:
  • Single 712 female 5-pin Binder connector
  • Double 712 female 5-pin Binder connectors
  • Single lead to RCA cables
  • Double lead to RCA cables
SKU: MIR
Guida per l'utente della telecamera di retromarcia
Scheda tecnica della telecamera di retromarcia
