Aim OTK Kart Throttle Position Sensor Bracket
Choose Accessories
Mount Your System
The Aim Throttle Position Sensor Bracket is a mounting bracket made specifically for use with the throttle position sensor kit, designed for OTK karts.
Why Choose the Aim Throttle Position Sensor Bracket
The Aim Throttle Position Sensor Bracket secures the sensor directly onto the throttle cable (rather than onto the pedal) by clamping to the throttle cable’s sleeve. It ensures accurate positioning and stable alignment of the sensor relative to the magnet. An OTK cable holder for the magnet is available to purchase separately.
Staffa del sensore di posizione dell'acceleratore
