1 di 5
AiM Remote Input / Output Module
SKU: I-O-Module
Prezzo regolare
£125.00
Prezzo regolare
Prezzo di vendita
£125.00
The RIO02 Remote Input/Output Module is dedicated to pushbutton management when the available inputs are not enough.
Key Features:
  • CAN Connections - 1
  • 8 programmable Switch to Batt
  • 11 Switch to ground
  • 2 low side outputs
  • Free race studio 3 download
  • 5 pin 712 male connector
The RIO02 Remote Input / Output Module is dedicated to push button management when the available inputs are not enough.
It features 19 inputs, primarily dedicated to push button management. Easily configure momentary, two-position, and multi-status, with momentary controls for long and short push.
It has 2 Low side, max 2A, digital outputs as well.
Unlock your potential
  • CAN Connections
  • Inputs: 19 of which  - 8 prog: switch to Batt, Switch to ground, 11 Switch to Ground
  • Dig Outs: 2 Low Side 2 A Max
  • Body: Plastic
  • Connectors: 1 AMP 776087-1 connector
  • Weight: 129g
Key Features:
  • CAN Connections
  • Body: Plastic
  • Weight: 129g
Whats In The Box
