Aim SmartyCam 7-Pin External Power Cable, ECU CAN & Female Jack Plug for External Microphone
Power Your System
The Aim SmartyCam ECU Harness is an external power cable that provides a 12V power supply to the camera, with a female jack plug for an external microphone to be connected. The cable is available in 2 or 4 metre lengths and is compatible with the Aim SmartyCam 3 & 4 Corsa, 3 GP and 2.2 GP/GP HD.
Why Choose the SmartyCam Microphone Power Cable
The power cable is a useful accessory for when you want the reassurance of having the camera powered from your vehicle's 12V system. The 3.5mm female jack plug allows you to connect an on-board radio to an intercom system (additional cable may be required depending on your radio/intercom). Essentially, the Aim SmartyCam 7-Pin External Power Cable, ECU CAN & Female Jack Plug for External Microphone provides direct battery power supply to an Aim SmartyCam camera, external microphone connection, and features CAN high and CAN low connection inputs for the ECU.
Please Note: This connection cable is not required if you are connecting the SmartyCam to a logger or dash, as the power will be supplied to the camera through the CAN connection.
Cavo di alimentazione, ECU CAN & con spina jack
