Vai direttamente ai contenuti
Accedi
Cerca
Cerca Accedi Carrello 0
Carrello
Il tuo carrello è vuoto.
  • Continua lo shopping
    Ordina istruzioni speciali
    Subtotale
    Visualizza carrello
    Cerca
    Aim SmartyCam Bullet Camera U Bolt Mount - AimShop.com
    SM-UB-GP
    In magazzino, pronto per la spedizione
    £80.00
    • Condividi su Facebook
    • Condividi su WhatsApp
    • Condivide via e-mail
    • E-mail Condivide via e-mail
    Product Image
    £80.00
    Aim SmartyCam GP HD Bullet Camera U Bolt Mount
    The SmartyCam GP HD 2.1, 2.2 & 3 (bullet camera) U bolt mount has been designed to hold and position the bullet camera.
    Fits the SmartyCam GP HD camera Ball & socket adjustment system
    Suitable for 0.5 to 1.2" bar For SmartyCam GP HD 2.1, 2.2 & 3
    Aim SmartyCam GP HD Bullet Cam U Bolt Mount
    The Aim SmartyCam GP HD U bolt mount is for mounting a SmartyCam GP HD 2.1, 2.2 & 3 to your vehicle. The mount has been designed to mount to a roll bar, railing or tube that have a diameter of between 0.5 to 1.2".
    The U bolt clamp has a unique ball and socket system which has been designed to cope with the rigours of motorsport.
    U Bolt Mount
    Securely attaches to any rollbar, railing or tube with a diameter of 0.5 to 1.2"
    • For use with SmartyCam GP HD 2.1, 2.2 & 3
    • 60mm (2.36 inches) arm
    • U bolt
    • 60mm arm
    • Ball head
    • Bullet cam bracket
    Technical sheet Race Studio 3
