Aim SmartyCam Roll Cage Mount
Mount Your System
The Aim SmartyCam Roll Cage Mount is the simple and secure solution to mounting your SmartyCam to your vehicle. It is suitable for the SmartyCam 2.1, 2.2, 3 and 4 in a variety of different models, including the Sport, Corsa and HD.
Why Choose the Aim SmartyCam Roll Cage Mount
The Aim SmartyCam Roll Cage Mount is the most secure and easiest way to view your SmartyCam when you’re on the track in your vehicle. The mount is simple to attach, suiting a variety of roll cage diameters for the perfect setup. The ball and socket allows you to conveniently position the camera to suit your lap line, ensuring maximum visibility of your laps for post-session reviews.
Supporto per roll-bar SmartyCam
