Upgrade your motocross setup with one of the best motocross lap timers in the industry — the Solo 2 DL Track Day Kit. Now available as a plug & play unit, display instant speed, timing splits, live data and predictive lap times on a high-contrast display with an accuracy of up to two-hundredths of a second, all specific to your bike model, just plug it in and go! See your exact riding line, compare it to optimal lines for faster lap times, track your bike’s movements and provide detailed data on acceleration, braking, and cornering forces. Do all of this and more with direct ECU data logging for instant, trackside, or post-race analysis with all your logged performance data.
Carica il video: Aim Solo 2 DL Lap Timer on motorbike dash
Why Choose the MX Solo 2 DL Track Day Lap Timer Kit
Building on the features of the Aim Solo 2 model, the Solo 2 DL MX lap timer connects directly to your bike’s ECU to record vital engine data, without the need for complex wiring. Compatible with a wide range of motorsport applications and bike ECUs, the Solo 2 DL is a versatile tool for helping motorsport professionals monitor and improve their performance in any motorsport discipline.
Carica il video: Solo 2 DL on Ducati motorcycle
Plug & Play Compatibility
The kit comes with a cable to connect the Solo 2 DL to your bike, relaying all vital ECU information. The cable is specific to your bike model.
Plug & play is currently available for the following bike models:
  • TM Racing
  • GET GP1 & GET Power
  • Suzuki
  • Microtec M222
  • Microtec M206
  • Honda
Please select your model before adding the Solo 2 DL Plug & Play Kit to your cart.
Solo 2 DL is compatible with Suzuki, Honda, TM Racing, GET, Suzuki and MicroTech motocross bikes
The Solo 2 DL motocross lap timer has a sharp, high-contrast display which helps riders easily identify the data displayed on screen, as well as 8 different backlight colours.
Thousands of pre-loaded worldwide track maps are available, the bike lap timer automatically recognises your position on the track as soon as it's switched on. Once you start to ride, it automatically recognises the start line coordinates of the track and starts sampling lap times every time you ride past.
The Solo 2 DL allows you to create a new temporary or permanent track layout too. Even if there is no track already, the device will create one for you.
Inertial Platform
To take your data one step further, the Aim Solo 2 DL seamlessly connects to Aim SmartyCams and a variety of MX sensors to increase your data performance and enhance your analysis with the added visuals and overlays, as well as additional sensor information.
  • Display: Graphical LCD
Integrated Track Database
  • Over 4,000 worldwide
  • Wi-Fi Connection: Yes
  • GPS: 25Hz
  • External Power: 9-15V
  • Memory: 4GB
SKU: SOLO2
Pinouts
Solo 2 DL pinout
  • Solo 2 DL front view
    Solo 2 DL
  • Cable icon
    Power Cable with AC Adapter
  • Cable icon
    Your Chosen Connection Cable
Solo 2 DL Tech Sheet
Solo 2 DL User Guide
Videos
Overview
Carica il video: An in-depth review of the main features and functions of the Aim Solo 2 DL motocross lap timer.
What is the best track day lap timer?
The Aim Solo 2 DL is a high-precision, 25Hz GPS lap timer. It connects directly to your motocross bike’s ECU to provide detailed performance data such as speed, RPM, throttle position and more. It provides accurate lap times, split times and predictive timing, with advanced data logging capabilities, making it one of the best compact data logging lap timers with an integrated display for track days.
How does the Aim Solo 2 DL lap timer work?
The Aim Solo 2 DL is a data logging GPS lap timer that allows you to analyse instant speed, timing splits, live data and predictive, theoretical and delta times. It connects directly to the MX bike's ECU and multiple satellite constellations (GPS and GLONASS), providing performance data in real time.
The Aim Solo 2 DL uses a range of different technologies to enhance user experience. It has a 25Hz GPS receiver for precise lap timings and position markers, a 100Hz 6-axis inertial platform that provides data on roll, pitch and yaw. It also has integrated data logging capabilities via CAN bus, for advanced and comprehensive data logging.
How do you connect the Aim Solo 2 DL to the motocross bike’s system?
This Aim Solo 2 DL kit comes with a specific plug and play cable for your selected motocross bike's ECU if compatible.
Which motocross bike models are the plug & play compatible with?
This Solo 2 DL Kit comes with a cable to connect the Solo 2 DL to your MX bike, relaying all vital ECU information. The cable is specific to your bike model and is currently available for the following bike models:
  • Honda CRF 250CC from 2010 and CRF 450CC from 2009
  • TM Racing SMX 450 F1, MX 250 F1, MX 450 F1, EN 250 F1 and EN 450 F1 all from 2015
  • Microtec M222 and M206
  • Suzuki RMZ 250CC 4-stroke (2010 - 2013) and RMZ 50CC 4-stroke (2008 - 2013)
The Solo 2 DL can work seamlessly with our SmartyCam series for data overlay and high-quality recordings. It can also be paired with an Aim ACC3 to add 4 additional analogue channels for external sensors. Data Hubs can also be added to the system to provide additional CAN channels, which is ideal if you're already using the CAN expansion port. Please see the "Connections" tab for more examples.
Aim Solo 2 DL
Aim Solo 2
  • 4GB Internal Memory
  • Automatic Track Recognition
  • Integrated GPS
  • Ten Configurable RGB LEDs
  • Wi-fi Connectability
  • GLONASS Receiver
  • Direct ECU Data Logging
  • Predictive Lap Timing
  • Choice of Connection
  • Integrated GPS
  • Graphical Display
  • Solo 2 DL
  • Choice of connection Cable
  • Solo 2
  • GPS: 25Hz
  • Memory: 4GB
  • GPS: 25Hz
  • Memory: 4GB
