Aim Solo, Solo 2 & Solo 2 DL Roll Bar Mount (V Bracket)
Mount Your System
The Aim Roll Bar Mount (V Bracket) is suitable to be clamped to a roll bar, railing or tube, and is used to mount Aim Solo, Solo 2 and Solo 2 DL GPS Lap Timers. Using the ball and socket system and a dual swivel joint that allows you to adjust the viewing angle, the Aim Solo Roll Bar Mount allows you to securely position the lap timer in the optimum position.
Why Choose the Aim Solo Roll Bar Mount
Designed specifically for the Aim Solo, Solo 2 and Solo 2 DL, the Roll Bar (V Bracket) Mount allows you to quickly and easily mount the lap timer, so that it won’t move, fall or cause any distractions to the driver. The dual swivel joint makes it easier to conveniently position the lap timer to face you, so that you can quickly monitor and improve your timings hands-free, without compromising on visibility. The securing clip also has a rubber lining to prevent slipping and any vibrations from affecting the display.
Solo Roll Bar Mount
