Vai direttamente ai contenuti
Accedi
Cerca
Cerca Accedi Carrello 0
Carrello
Il tuo carrello è vuoto.
  • Continua lo shopping
    Ordina istruzioni speciali
    Subtotale
    Visualizza carrello
    Cerca
    Aim Solo Spare Backing Plate - AimShop.com
    SOLO-BP
    In magazzino, pronto per la spedizione
    £30.00
    • Condividi su Facebook
    • Condividi su WhatsApp
    • Condivide via e-mail
    • E-mail Condivide via e-mail
    £30.00
    The Aim spare backing plate is designed for mounting the Solo GPS Lap Timer.
    Key Features:
    Spare backing plate Suitable for Solo GPS lap timer
    The Aim spare backing plate to suit the Solo enables you to mount your Solo to most flat surfaces. The Solo has two large integrated magnets on the back that hold it in place, so you can simply install or remove it with ease.
    Standard original mount ideal for use as a spare.
    Mount onto flat surfaces
    • 1 Solo Backing Plate
    • 2 screws
    • 2 washers
    • 2 nuts
    • Solo Backing Plate
