Two-Way CAN Connection Multiplier
The compact two-way data hub with an external power cable provides two additional CAN channels and works as an interface between Aim data loggers and accessories. It also features a 12V external power connection.
Why Choose the Two-Way Data Hub
Using many devices can result in excessive wiring, but with the data hub, all unnecessary wiring can be eliminated. Aim data hubs take all the information you need to your logger with only one cable, minimising wires overall, and are available in the following versions to suit your setup:
The compact two-way data hub with 12V flying cables provides a CAN channel and works as an interface between Aim loggers and accessories. Additional devices, such as GPS modules, SmartyCams and Lambda sensors can be added to provide extra data from your vehicle and improve performance.
You can also use the two-way data hub with external power cable with our MX series dashes and display loggers, powered by the vehicle's onboard battery supply.
Note: You can connect multiple data hubs to build a wider network.
Connection
  • 5-Pin 712 Male Binder
  • 2 Flying Leads 12V
  • Dimensions: 70 x 30 x 23.5mm
  • CAN Cable Length: 40cm
  • Source Cable Length: 165cm
  • Weight: 86g
SKU: S-2PH-K
Aim Two Way Data Hub CAN Connection Multiplier with External Power Pinout
Data Hub Tech Sheet
What sizes are available for the Aim Two-Way Data Hub CAN Connection Multiplier?
The Aim Two-Way Data Hub is available as a Two-Way or Two-Way with External Power and comes with a 40cm cable to suit your setup.
What can be connected to the Aim Data Hub CAN Connection Multiplier?
Data Hubs communicate with Aim loggers using the Aim CAN network (5-pin 712 binder connector) and are needed to mutually connect more expansions, but are not needed to connect the sensors to Aim loggers. Supported expansions include:
  • Other Data Hubs
  • GPS Module
  • Lambda Controller
  • SmartyCam
  • ACC3
  • Loggers
