Vai direttamente ai contenuti
Accedi
Cerca
Cerca Accedi Carrello 0
Carrello
Il tuo carrello è vuoto.
  • Continua lo shopping
    Ordina istruzioni speciali
    Subtotale
    Visualizza carrello
    Cerca
    Link MINIX PlugIn ECU for MINI Hatch R50–R53, compact plug-in engine control unit module
    Link MINIX PlugIn ECU for MINI Hatch R50–R53, Link Plug In ECU module with connector pins
    MINIX
    MINI Hatch R50 – R53 Link - MINIX PlugIn ECU
    Prezzo scontato£1,147.50
    Prezzo di listino £1,275.00
    • Condividi su Facebook
    • Condividi su WhatsApp
    • Condivide via e-mail
    • E-mail Condivide via e-mail
    Prezzo scontato£1,147.50Prezzo di listino £1,275.00
    Our ECU comes in its own case which fits directly into the factory location.
    Installation is a breeze, with no alteration of the factory wiring loom required for the models listed below.
    This ECU is designed for the R50-R53 Tritec 1.6 SC engine.
    Please check your pinout connector matches the header in the listed photo before purchasing.
    An XS Loom and 4 Bar Map Sensor highly recommended (sold separately).
    Suitable Applications:
    R50 –R53 MINI Hatch with the 1.6l SC engine
    *Chronopack dash option not currently supported
    PlugIn Key Features (where applicable):
    Sequential fuel delivery
    OEM idle hardware supported
    CAN port
    USB tuning cable included
    Staged injection
    Knock with "windowing"
    I/O Expansion Options:
    Aux1 -  Auxiliary Output
    DI8 -  Digital Input
    DI9 -  Digital Input
    An Temp 3 -  Temperature sensor input
    An Temp 4 -  Temperature sensor input
    An Volt 10 -  Analog 0-5V input
    An Volt 11 -  Analog 0-5V input
    +5V Out -  Low Current +5V Supply
    GND -  Sensor Ground Only
    *Please see the PC Link Help file for details regarding installing the Expansion Cable.
    MINI hatch R50 – R53 Link - MINIX PlugIn ECU
    • G4X PlugIn ECU
    • Stickers
    • Domande frequenti
    • Video di supporto
    • Guida al prodotto PDF
    • Contattaci
    • Diventa un ambasciatore
    • Riparazioni
    • Chat dal vivo & Supporto
