Vai direttamente ai contenuti
Accedi
Cerca
Cerca Accedi Carrello 0
Carrello
Il tuo carrello è vuoto.
  • Continua lo shopping
    Ordina istruzioni speciali
    Subtotale
    Visualizza carrello
    Cerca
    Link MX5Link - MX5NB1X PlugIn ECU - AimShop.com
    MX5NB1X
    £1,175.00
    • Condividi su Facebook
    • Condividi su WhatsApp
    • Condivide via e-mail
    • E-mail Condivide via e-mail
    £1,175.00
    G4X PlugIn ECUs offer the latest in engine management technology, designed to easily maximize the potential from your car.
    Designed for the Pre-Facelift MX5 NB (MY1998-2000, 3 Plug ECU, non-VVT 1.8L Engine)
    • Please check your connector matches the header in the listed photo before purchasing.
    • This ECU works for manual transmissions only.
    • Includes onboard 7 bar MAP sensor
    • Most factory features are supported
    • Check the features tab for I/O expansion options
    Note: This Plug-in features a new 4 pin powered CAN connector and cannot use the old CANPCB cable for CAN connection. Use the CANJST4 (Link PN 101-0198) cable for connecting CAN devices. This new 4 pin port and cable provide not only the CAN connection, but also a protected 12V power supply and ground for powering the CAN devices. The power supply is protected by a self-resetting fuse rated at 3A continuous.
    PlugIn Key Features:
    Precision closed loop cam control (four cam, independent control)
    Sequential fuel delivery
    OEM idle hardware supported
    Motorsport features - anti lag, launch, flat shift
    Continuous barometric correction (on board)
    CAN port
    QuickTune - automated fuel tuning
    USB tuning cable included
    Real time selectable dual fuel, ignition and boost maps
    512 mega bytes data logging memory
    Staged injection
    Knock with "windowing"
    I/O Expansion Options:
    Expansion Connector 1
    Pin 1                An Temp 4
    Pin 2                An Temp 3
    Pin 3                DI 10
    Pin 4                DI 9
    Pin 5                DI 8
    Pin 6                DI 7
    Pin 7                IGN 4
    Pin 8                IGN 3
    E-Throttle Connector
    Pin 1                Ground (signal)
    Pin 2                +5V out
    Pin 3                An Volt 12
    Pin 4                An Volt 11
    Pin 5                An Volt 10
    Pin 6                An Volt 9
    Pin 7                Aux 10
    Pin 8                Aux 9
    Specifications
    The PlugIn ECU is capable of the following features, if the car it is being used in will support them.
    Engine Configurations
    • 1-12 Cylinder Distributed
    • 2-12 Cylinder Wasted Spark
    • 1-8 Cylinder Direct Spark
    • Odd Fire Engines
    • 2-Stroke, 4 Stroke and Rotary Engines
    • Configurable Firing Order
    • Configurable TDC Points (for odd fire)
    Inputs/Outputs
    • 8 x High Current Injector Drives (suits high impedance injectors)
    • 8 x Ignition Channels
    • 8 x Auxiliary Outputs (All PWM capable). Aux5-8 can control Stepper Motors and drive High or Low
    • 11 Digital Inputs (All capable of reading frequencies up to 10kHz)
    • +5V Out
    • +8V Out
    • 4 Temperature Inputs (Configurable pull-ups on ANT1&2)
    • 12 x 0-5V Analogue Inputs
    • 2 x Trigger Inputs (Reluctor, Optical or Hall Sensors)
    • On Board Baro
    • 3 Axis Accelerometer
    Fuelling adjustments
    • Traditional, Modelled and Modelled Multi-Fuel Equations
    • Single-Point Group, Multi-Point Group, Sequential, Semi-Sequential, Group Staged, Sequential Staged and Sequential/Multi Point Group Staged injection modes
    • Asynchronous injection (can add more fuel after initial injection if conditions change)
    • Quick tune (automated fuel tuning)
    • Up to 440 Zone Fuel Table with configurable load and RPM centres. Configurable X and Y Axis Parameters
    • Multiple Fuel Tables
    • Up to 6D Fuel Mapping (3D Fuel Table + 3x3D Overlay trim tables)
    • Injection Rate Control for Group Injection Modes
    • Master Enrichment for Traditional Fuel tuning
    • Pre-Crank Prime
    • First Crank Prime
    • Crank Enrichment
    • Post Start Enrichment
    • Warm Up Enrichment
    • Acceleration Enrichment
    • IAT Fuel Correction
    • Injector Deadtime Compensation
    • Injector Short Pulse Width Compensation
    • Injector Timing Control with Beginning, Middle or End Injection Definable
    • AFR Table Correction
    • Dual Closed Loop Lambda
    • Individual Cylinder Fuel Trims
    • Overrun Fuel Cut
    • Idle Load Trims
    • Fuel Temperature Correction
    • Barometric pressure compensation
    • Injector test function
    Ignition Adjustments
    • Distributor, Twin Distributor, Wasted Spark, Direct Spark, Rotary leading Wasted and Rotary
    • Leading Direct Ignition Modes
    • Up to 440 Zone Ignition Table with configurable load and RPM centres. Configurable X and Y Axis Parameters
    • Configurable Maximum Advance
    • Configurable Spark Duration
    • Configurable Spark Edge
    • Dwell Time Table with configurable X and Y Axis Parameters
    • Multiple Ignition Tables
    • Up to 6D Ignition Mapping (3D Ignition Table + 3x3D Overlay Trim Tables)
    • Individual Cylinder Ignition Trim
    • IAT Trim
    • Voltage Correction
    • ECT Trim
    • OEM Compatibility
    • CDI Compatibility
    • Transient ignition retard
    • Adjustable ignition delay compensation
    • Ignition test function
    • Idle ignition control
    Limits
    • Engine Temperature Dependent Progressive Limiting
    • Dual Vehicle Speed Limits
    • System Voltage Limit
    • User Configurable RPM Limits based on external input
    • MAP Limit with dual tables
    • Optional hard cut
    • Progressive cut control
    • Selectable fuel or ignition limiting
    • Ignition trim and configurable trim decay
    • Adjustable control range
    • Selectable cut effect (adaptive or constant)
    Auxiliary Output Options
    • Each Output independently configurable
    • Unused ignition and Fuel outputs available as auxiliary outputs
    • General Purpose Outputs
    • General Purpose PWM Outputs
    • Fuel Pump Control
    • Fuel Pump Speed Control
    • Engine Fan Control
    • Air Con Clutch Control
    • Air Con Fan Control
    • Intercooler Spray Control
    • Tacho Control
    • Speedo Control
    • Check Engine Light
    • Purge Solenoid
    • Oxygen Sensor Heater
    • Switched Cam Solenoid Control
    • ECU Hold Power Control
    • Shift Light Control
    • Starter Control
    • VVT Cam Solenoid
    • Boost Control Solenoid
    • Test functions for each output
    • Closed loop Stepper Control & Rotary Oil Pump Control
    • Idle Speed Soloenoid
    • Idle Speed Stepper
    • Internal Ethrottle Controller
    • External EThrottle
    Digital Inputs
    • Each channel independently configurable with pull-up resistors and active state control
    • All digital inputs capable of reading frequencies of up to 10kHz
    • Duty Cycle measuring on all digital inputs
    • Turbo speed
    • Ethanol Sensor Control
    • Wheel Speed Detection on all digital inputs with additional general-purpose speed inputs
    • Anti-Theft control through digital inputs, over CAN or both
    • General Purpose switches, speeds, rpms and frequencies
    • large variety of input types
    Analogue Inputs
    • Each input independently configurable with pre-set or custom calibrations and configurable fault conditions
    • Built in 3 axis accelerometer
    • Built in Barometric Pressure Sensor
    • Large variety of Analogue input functions
    • General Purpose Temperatures, Pressures, Rotary Switches and more
    • Analogue Inputs can also be used as Digital Inputs
    • Large number of built in calibrations
    • Ten Calibration Tables and 3 Linear Calibrations for when a custom calibration is required
    Triggering
    • Digital Trigger Decoding
    • Reluctor, Optical Proximity or Hall Sensors
    • Programmable filtering and arming thresholds
    • Configurable trigger patterns or pre-set triggering options
    • Supports nearly all OEM trigger patterns and custom trigger arrangements
    Programmable Math Processing
    • Eight individually controllable math channels with up to four parameters in each
    • Math channels can be used as table axis’s and as digital or analogue inputs
    Motorsport Features
    • Anti Lag
    • Launch control
    • Gear Shift Control (Digital Inputs, Gear Lever Force or Gear Barrel Position)
    • Traction control
    Anti-Lag System
    • Dual 3D Fuel enrichment, Ignition cut and Ignition retard Tables
    • Optional Cyclic idle (normal and cool-down)
    • Optional 3D Idle controller Override Tables (one for Anti lag and one for Cyclic Idle)
    • Lockout conditions based on engine speed and throttle position with hysteresis
    Launch Control
    • Single RPM, 3D RPM Table or Latched (RPM when button pressed) Launch modes
    • Vehicle speed controlled
    • Ignition Trim with optional 3D table and relative or absolute ignition angle options
    • Optional 3D Fuel Trim table
    Gear Shift Control
    • Digital input (clutch switch), gear lever force (sequential gearbox), gear lever force (H pattern gearbox), and gear barrel position sensor input options
    • Timed or controlled modes
    • Adjustable progressive cut levels
    • Power re-introduction control
    • Ignition retard control
    • Fuel enrichment control
    • Cut duration based on gear
    Traction Control
    • Disable switch
    • Various Lockout conditions
    • Multiple 3D slip Threshold tables
    • Traction Control - controlled tyre slip to improve vehicle safety and driveability
    • Uses an advanced Torque Management system to reduce engine torque
    Idle Control
    • Solenoid, Stepper or EThrottle Control
    • Open or Closed loop actuator control and Closed loop Ignition control available
    • Large variety of position offsets for open loop and additional target offsets for closed loop actuator control
    • Specific start-up offsets and hold times
    • Dashpot functionality to smooth re-entry into idle and prevent undershoot
    Electronic Throttle Control
    • Has an internal EThrottle Controller and supports external controllers
    • Multiple 3D target tables
    Boost Control
    • Open or Closed Loop Boost Control
    • Multiple Target and Base Position Tables
    • Multiple Trim tables
    • Boost by Gear control
    Knock Control
    • 2 Built in Knock inputs
    • Fuel Enrichment and Ignition Retard functionality
    • Adjustable frequency filter
    • Adjustable gain (per cylinder)
    • Individual cylinder detection
    • Individual cylinder ignition retard and fuel enrich
    • Adjustable detection angle (start/end)
    • Noise threshold table (3D)
    • Adjustable ignition retard and fuel enrich sensitivity
    • Configurable ignition reintroduction and fuel enrich decay
    Variable Valve Timing Control
    • Up to 4 cams independent control
    • Supports many OEM applications
    • Closed loop control
    • Multiple 3D Cam angle target tables
    • Optional advanced PID control settings for advanced tuners
    • Automatic function for calibrating cam angles
    Chassis and Body
    • AC Control - Basic and Advanced modes available
    • AntiTheft - Via Digital Input, CAN or both
    • Speed based cruise control (EThrottle only)
    • Gear Detection - CAN, RPM/Speed or Analogue Position Sensor
    • Individual wheel speed sources with the ability to specify Driving and Non-Driving wheel speed sources
    • Starter control - Multiple options available from very basic to Touch to start.
    Torque Management
    Logging
    • 512 Megabytes of Datalogging
    • Up to 250 ECU Logging channels
    • Up to 1kHz per channel with a maximum total sample rate of 100kSamples/s when using ECU Logging
    • Unlimited channels when using PCLink logging
    Communications
    • Tuning Port USB on board
    • Two CAN buses
    • Custom CAN configuration allowing tuners and end users to add support for new CAN devices
    Processing
    • 150 MHz Specialised Engine Management Microprocessor
    • Ignition control to 0.1 degree, fuel to 0.01 ms
    • 32 Bit Floating Point Calculation
    • 12 Bit ADC Resolution
    • 20000+ RPM
    • 4Gb Non Volatile Flash
    Environment
    • Internal Temperature Range -10 - 85oC
    • Ambient Temperature Range -30 - 90oC
    • Voltage 8 - 22V
    • Operating Current 200mA
    • Electrical protection on all inputs and outputs
    • Onboard Barometric Pressure Sensor
    Packaging Contents
    • G4X PlugInX ECU
    • 2 large Link Stickers
    • 2 small Link Stickers
    Additional Accessories (purchased separately)
    • Intake Air Temperature Sensor
    • 3/8 NPT (Aluminium or Steel Mounting Bosses to suit)
    • 3 Channel Link Igniter
    • Throttle Position Sensor
    • Wideband O2 Controller & Sensor
    • Injector Ballast Resistor Packs
    • G4X PlugIn ECU
    • Stickers
    Link Download
    • Domande frequenti
    • Video di supporto
    • Guida al prodotto PDF
    • Contattaci
    • Diventa un ambasciatore
    • Riparazioni
    • Chat dal vivo & Supporto
