Vai direttamente ai contenuti
Accedi
Cerca
Cerca Accedi Carrello 0
Carrello
Il tuo carrello è vuoto.
  • Continua lo shopping
    Ordina istruzioni speciali
    Subtotale
    Visualizza carrello
    Cerca
    Link Nissan S15Link - #NS15X PlugIn ECU - AimShop.com
    NS15X
    £1,475.00
    • Condividi su Facebook
    • Condividi su WhatsApp
    • Condivide via e-mail
    • E-mail Condivide via e-mail
    £1,475.00
    Designed for the SR20 engine. This ECU will work with the 64 pins, blue header plug ECU version.
    ECU includes an onboard 4 bar MAP or 7 bar MAP sensor.
    Suitable Applications:
    S13 Silvia / 180SX SR20DET (but not CA18DET)
    S14a Silvia (facelift) SR20DET
    S15 Silvia SR20DET
    S15 Silvia SR20DE
    RNN14 Pulsar GTI-R SR20DET
    N15 Pulsar SR16VE
    N14 Distributed
    *For the 76 pin header ECU, have a look at the S13X PlugIn listing.
    Sequential fuel delivery
    OEM idle hardware supported
    CAN port
    USB tuning cable included
    Staged injection
    Knock with "windowing"
    I/O Expansion Options:
    Expansion connector 1
    Gnd Sensor Ground Only
    DI6 Digital Input
    DI7 Digital Input
    An Volt 5 Analog 0-5V input
    An Volt 6 Analog 0-5V input
    Expansion connector 2
    Ign 5 Ignition 5 Auxiliary output
    Ign 6 Ignition 6 Auxiliary output
    Ign 7 Ignition 7 Auxiliary output
    DI 8 Digital Input
    Volt 8 Analog 0-5V input
    Volt 9 Analog 0-5V input
    Volt 10 Analog 0-5V input
    Volt 11 Analog 0-5V input
    • G4X PlugIn ECU
    • Stickers
    • Domande frequenti
    • Video di supporto
    • Guida al prodotto PDF
    • Contattaci
    • Diventa un ambasciatore
    • Riparazioni
    • Chat dal vivo & Supporto
