Link Throttle Position Sensor (TPSCW/CCW)
The Link throttle position sensor (TPS) supports clockwise and anticlockwise installations. It contains a 6-wire flying lead, and wiring instructions are provided in the box for ease of set-up.
Why Choose the Link Throttle Position Sensor
The Link throttle position sensor mounts securely onto an 8mm D-shaft, preventing slippage and ensuring precise alignment. It uses hall effect non-contact technology to detect magnetic fields rather than relying on moving parts, resulting in exceptional durability and a long service life.
The TPS features a 32mm pitch circle diameter (PCD) for straightforward installation and includes dual redundant outputs, providing a backup signal to maintain reliability even if one output fails.
Sensore di posizione dell'acceleratore
