Enhance Your Sim Racing Experience
The 5” MXS 1.3 Strada sim racing dash is a premium, high-contrast TFT display designed specifically for sim racers who demand the very best. With customisable RGB shift lights and professional-grade functionality, the MXS Strada is a compact sim racing dash that bridges the gap between gaming and real-world motorsport experiences.
Why Choose the MXS Sim Racing Dash Display
Sim racing has evolved. No longer a hobby bolted to the kitchen table, it now mirrors the professionalism of global racing championships, and the demands are higher than ever. That’s why both e-racers and real-world drivers trust Aim, a data-driven leader in motorsport technology, to deliver the same cutting-edge tools used by world-class racing teams.
  • Trusted by world-class motorsport teams worldwide.
  • Cutting-edge technology brought directly from the track to your simulator.
  • Unmatched data accuracy and visualisation for serious racers.
Configurable Display
Integrated Shift Light Array & LEDs
The MXS Strada display also comes with 6 RGB LEDs, allowing you to customise colours, alarm types (solid or flashing), flashing frequency and accompanying text messages. Alarm priorities can be set to suit your specific requirements.
Advanced Data Analysis with Race Studio 3
Harness the power of Aim’s free, professional software, Race Studio 3. Import your session data and analyse every lap with the same tools real racing teams use. Identify strengths, pinpoint mistakes, and unlock performance gains with unrivalled precision, so you can train, compete, and improve like a pro.
By connecting via USB, the MXS Strada display transforms your sim rig into a true Aim dashboard. Get real time race data, lap timing, and predictive lap timing displayed directly in front of you—just like in a real race car.
  • Ambient Light Sensor: Yes
  • CAN Connections: 2
  • Second CAN: Yes
  • Body: Anodised aluminium
  • Power Consumption: 400mA
  • Display: 5" TFT
  • Contrast: 600:1
  • Weight: 480g
SKU: MXS-S-SIM
Guida per l'utente di Sim Technology
MXS Strada User Guide
MXS Strada Tech Sheet
Can I use an MXS Strada Display for sim racing?
Although predominantly used for road/track use, Aim provides simulator functionality for the MXS Strada Display through suitable firmware. Confirm the firmware and connections for your sim rig before moving it between applications.
Does an MXS Strada Display record sim racing data itself?
Treat display output and session recording as separate requirements. Check how your simulator exports or records data for analysis, and ask us to confirm the exact device capabilities if you want onboard logging.
Can I add an Aim Display without changing my steering wheel?
If your steering wheel is compatible with an Aim Display, you don't need to change your steering wheel. You will just need suitable mounting space and the correct power, connection and software setup for the chosen display.
Can I use Aim Displays with PlayStation or Xbox?
The simulator documentation covers Windows PC use only. Contact us before buying an MXS Strada Display for a console setup so we can confirm compatibility with your exact equipment.
Is a larger display always the better choice?
Choose the display that fits your viewing distance and cockpit layout. A clear, unobstructed smaller screen can be a better fit than a larger unit that clashes with the wheel or monitor position.
MXS Strada
MXP Strada
MXG Strada
  • 5" TFT display
  • 10 shift light RGB LEDs
  • For sim racing
  • 6 alarm RGB LEDs
  • 8 analogue inputs
  • Configurable displays
  • 6" TFT display
  • For sim racing
  • 5 alarm RGB LEDs
  • 8 analogue inputs
  • 7" TFT display
  • For sim racing
  • 8 alarm RGB LEDs
  • 8 analogue inputs
  • Weight: 480g
  • Weight: 590g
  • Weight: 950g
  • MXS Strada Dash
  • 14-Pin Standard Wiring
  • MXP Strada Dash
  • MXG Strada Dash
  • Second CAN: Yes
  • Body: Anodised Aluminium
  • Second CAN: Yes
  • Second CAN: Yes
  • Display: 5" TFT
  • Display: 6" TFT
  • Display: 7" TFT
  • Contrast: 1000:1
