Vai direttamente ai contenuti
Accedi
Cerca
Cerca Accedi Carrello 0
Carrello
Il tuo carrello è vuoto.
  • Continua lo shopping
    Ordina istruzioni speciali
    Subtotale
    Visualizza carrello
    Cerca
    Super B Display BM01 12V/24V - AimShop.com
    D
    £110.00
    • Condividi su Facebook
    • Condividi su WhatsApp
    • Condivide via e-mail
    • E-mail Condivide via e-mail
    £110.00
    superb lithium batteries
    The BM01 12-24V is a smart battery meter that can measure and display the voltage and the charge level (in percent) of a battery. It can also produce an alarm for a user programmable, low charge level. This device can be used for 12V and 24V applications Compatible with: Nomia and Epsilon
    Specifications
    PRODUCT SPECIFICATIONS
    Weight
    57.8 gr / 0.12 lbs
    Signal voltage (bat 1)
    6 VDC to 31 VDC
    Signal voltage (bat 2)
    0 VDC to 12 VDC
    Current consumption - Display on
    ± 20 mA
    Current consumption - Display off
    ± 8 mA
    Minimum cable diameter
    0.75 mm2
    Mounting Hole
    55 mm / 2.16"
    Installation depth
    18 mm / 0.7"
    Quickstart Guide
    Available to download Here
    User Manual
    Quickstart Guide
    • Domande frequenti
    • Video di supporto
    • Guida al prodotto PDF
    • Contattaci
    • Diventa un ambasciatore
    • Riparazioni
    • Chat dal vivo & Supporto
