Vai direttamente ai contenuti
Accedi
Cerca
Cerca Accedi Carrello 0
Carrello
Il tuo carrello è vuoto.
  • Continua lo shopping
    Ordina istruzioni speciali
    Subtotale
    Visualizza carrello
    Cerca
    Super B Touch Display (Displays Battery, Voltage, Current & Status) - AimShop.com
    TD
    £210.00
    • Condividi su Facebook
    • Condividi su WhatsApp
    • Condivide via e-mail
    • E-mail Condivide via e-mail
    £210.00
    superb lithium batteries
    Touch Display ( Displays Battery, Voltage, Current & Status )
    The Super B touch display is a smart battery meter that can measure and display the voltage, current, state of charge and time to go of your lithium battery. This gives you 24/7 insight in the available capacity of the battery. The touch display is suitable for 12 volt systems of the Nomia and Epsilon and can be set up in 6 different languages: English, French, German, Dutch, Italian and Spanish.
    Specifications
    PRODUCT SPECIFICATIONS
    Weight
    110 gr / 0.24 lbs
    Supply voltage range
    8 DC to 35 VDC
    self-discharge
    <3% per month
    Supply current
    80mA (max) / 6mA (SLEEP mode)
    Front display
    2,4-inch TFT colour screen with 320x240 pixel resolution
    Operating temperature
    -10°C to 50°C / 14°F to 122°F
    Storage temperature
    -20°C to 70°C / -4°F to 158°F
    Fixing
    4 screws
    Network protocol & connector
    CAN Bus / RJ11
    Dimensions
    Front Ø 93mm / Body Ø 72mm / Depth 27mm
    Quick Start Guide
    Available to download Here
    Mobile App
    Super B provides a Be In Charge Software tool which can be used to read out the internal BMS system. The software uses a CAN to USB converter to connect to the communication interface. The software is capable of reading out the actual status like battery/cell voltages and temperature but also statistical information. The Be In Charge software can also be used to update the installed firmware of the Li-ion battery. The Be In Charge software and hardware are not part of the Li-ion battery scope of delivery. Super B also provides a Be In Charge App for mobile devices such as Android and Apple. The app can be found in the Google play store or Apple app store.
    Super B app
    User Manual
    Quick Start Guide
    • Domande frequenti
    • Video di supporto
    • Guida al prodotto PDF
    • Contattaci
    • Diventa un ambasciatore
    • Riparazioni
    • Chat dal vivo & Supporto
