Vai direttamente ai contenuti
Accedi
Cerca
Cerca Accedi Carrello 0
Carrello
Il tuo carrello è vuoto.
  • Continua lo shopping
    Ordina istruzioni speciali
    Subtotale
    Visualizza carrello
    Cerca
    Suzuki GSX-R 1000 L7 AiM Solo 2 DL & EVO4S Logger Plug & Play Cable - AimShop.com
    SUZ-PP
    Suzuki GSX-R 1000 L7 Aim Solo 2 DL & EVO4S Logger Plug & Play Cable
    In magazzino, pronto per la spedizione
    £70.00
    • Condividi su Facebook
    • Condividi su WhatsApp
    • Condivide via e-mail
    • E-mail Condivide via e-mail
    £70.00
    Suzuki GSX-R 1000 L7 Solo 2 DL & EVO4S Logger Plug & Play Cable
    The AiM ECU plug & play cable has been specifically designed for Suzuki bikes. Allowing easy installation to a Solo 2 DL and EVO4S Data Logger. With a 7-pin 712 male binder connection.
    Suzuki plug & play cable 7 pin - 712 male binder connection
    Suzuki Plug & Play ECU Cable
    The AiM ECU plug & play cable has been specifically designed for the Suzuki bike. This plug & play cable can be used for the Solo 2 DL and EVO4S Data Logger.
    GSX-R 1000 L7 - 2017 onwards
    Example data protocols
    • Below is a pinout drawing for the Suzuki Solo 2 DL and EVO4S Data Logger plug & play connection cable
    • Suzuki GSX-R 1000 L7 Plug & Play connection cable
    Technical sheet Race Studio 3
