Vai direttamente ai contenuti
Accedi
Cerca
Cerca Accedi Carrello 0
Carrello
Il tuo carrello è vuoto.
  • Continua lo shopping
    Ordina istruzioni speciali
    Subtotale
    Visualizza carrello
    Cerca
    Triumph Daytona, Street Triple & Speed Triple AiM Solo 2 DL Plug & Play Cable - AimShop.com
    SOLO-K2-L
    Triumph Daytona, Street Triple & Speed Triple Aim Solo 2 DL Plug & Play Cable
    In magazzino, pronto per la spedizione
    £43.00
    • Condividi su Facebook
    • Condividi su WhatsApp
    • Condivide via e-mail
    • E-mail Condivide via e-mail
    £43.00
    The AiM ECU plug & play cable has been specifically designed for Triumph bikes. Allowing easy installation to a Solo 2 DL. With a 7-pin 712 male binder connection.
    Triumph plug & play cable 7 pin - 712 male binder connection
    Triumph Plug & Play ECU Cable
    The AiM ECU plug & play cable has been specifically designed for the Triumph bike. This plug & play cable can be used for the Solo 2 DL.
    The plug & play cable currently fits the following Triumph bike models:
    Daytona 675 - 2006-2012 Street Triple - 2007-2012
    Speed Triple - 2007-2012
    Example data protocols
    • Below is a pinout drawing for the Triumph Solo 2 DL plug & play connection cable
    • Triumph Daytona, Street Triple, Speed Triple Plug & Play connection cable
    Technical sheet Race Studio 3
